Karmjitrk.dyndns.org how can I this side view our laptop
    Master:
  • 663 Answers
What seems to be the problem? Please provide more information about your question. I can't seem to understand it.
David
Posted on Jul 30, 2013
Conect webcams on a local network to a website
I presume that you mean "from a web site" that the web site is hosted somewhere out on the greater internet.... The problem that you are encountering is probably related to NAT (Network address translation). The "In" side of a router, is typically a "private network" there are pre-assigned number groups for these - a common one is in the 192.168.x.x range. Problem is that the "outside" of your Netopia router will be dependent on your ISP< and unless you are paying them extra for a static IP address, is likely to change every time you reboot - or sometimes they bump them every 24 hours. So, first thing is get a dynamic DNS Entry - www.dyndns.org is one supplier - I think you can get one address for free from them, pay for more.. YOu set up something like CMVideo.dynsdns.org on their site, and set up dyndns support in the netopia router... Then you want to open the specific port on your router, to go to the internal IP Address of your camera. (YOu mention Multiple Cameras - depends on the Camera you may have to go for multiple dyndns (one for each...) ).
I am a little confused/concerned about the second router "tier" - if you have the Belkin configure as an Access Point only, all good, if you are trying to run it as a router behind a router, it will probably never work - double nat-ting" is a no no with most consumer Routers. Simple solution is to tap from Netopia lan side to Belkin Lan side (rather than Belkin Wan Side)
Nov 14, 2013 | Netopia Computers & Internet
Chipper model 47287 reverse wont stop when you let off lever very hard to change gears when running but when its off they are easy to change
Be gentle, that shift cable is NLA (I know, I need one).
It sounds as if the belt idler is not releasing. Take a look at the belt engage cable, Ref. No. 9 on this exploded view:
ftp://asavage.dyndns.org/Troy-Bilt/47287-ChipperVac/47287c-47287c02.07.gif
The spring at the end of that cable is what releases the idler from the belt. Another pic of the spring is near the idler arm Ref. No. 13 on this view:
ftp://asavage.dyndns.org/Troy-Bilt/47287-ChipperVac/47287c-47287c02.05.gif
If that spring is broken or missing, that would give the symptoms you describe.
HTH
Mar 30, 2013 | Troy-Bilt Chipper Shredder
Troy bilt chipper/vac model 47287 manual
I bought a bad photocopy of the Operator manual from a seller on eBay, and put it online:
[URL="http://asavage.dyndns.org/Troy-Bilt/"]http://asavage.dyndns.org/Troy-Bilt/[/URL]
It\'s not great quality, but it\'s better than nothing.
I\'ve got some parts manual pages there, too. Also of dubious quality, but you can make out the part numbers.
Mar 24, 2012 | Troy-Bilt Chipper Shredder
I need a static IP address can this happen with this cisco linksys router, Or do I need my ISP to sort it out?
Without your ISP you can't get a fixed IP.
What you can do is a workaround: use DynDNS.org if it sufficient to connect to a fix URL
DynDNS.org with translate a fix domainname into a dynamic IP-Address
Sep 15, 2011 | Computers & Internet
Hello, i setup a IP cam. Create an account on dyndns.org for the IP. But now when i type the given url i am linked to the setup of my Thomson router TG585 v8 What can I do? There is nothing else except...
Hi Sten -- There are several non-intuitive things you have to setup with any router and Dyndns to make this work.
On Dyndns you can setup your static or hardly every changing dynamic Internet (external - provided by your ISP) IP address in your Dyndns account settings (Not the internal NAT IP - 192.168.x.x address of the cam). if it changes more often you need a dyndns client.
On the router you have to setup port forwarding to the internal (NAT address ex:192.168.x.x) address of the camera including the port number -- or you could just create a DMZ (feature of many but not all routers) for the internal IP of the cam.
If you've done the above correctly you might want to check the troubleshooting sections at Dyndns.org located HERE and HERE.
Happy Networking and Thanks for using Fix Ya.
Mikeywaf
Apr 15, 2011 | Computers & Internet
I can not access my ip Foscam FI8918W camera from internet (dyndns.org)...port forward is not clear. I have a Verizon Router Actiontec GT704WG. I am supposed to access camera...
OK let me clear port forwarding for you, your router normaly has a firewall (to block of any requests from the internet to exploit any services trough any ports) so if you want access to a resource on the LAN side (side of the router where all the devices and computers are pluged) from the WAN side (side where the ISP's modem is connected for internet) you have to open a port or multiple ports to a specific device IP address (according to device manual).
for exemple:
assuming that the camera has an IP of 192.168.1.110 and it uses port 7777 for resources, in the port forwarding section of the router you ave to open port 7777 and direct it to 192.168.1.110 (save settings and VOILA)
enjoy!
Jan 04, 2011 | Actiontec (GT704WG) Router
DNS help...
DNs (Domain Name System)
DNS is used for resolving mapping between IP addreses and host names.
Means when you quary for yahoo.com computer only recognize bits and bytes format so but dnd resolves this isssue when it got yahoo.com quary it send request to ip addreses of yahoo.com.
If you change dns ip to that then all quary goes to tht dnd server if it has info for your quary then it forwards to there other wise you get page not found.
Aug 22, 2009 | 3Com 3CR858-91 Office Connect Cable/DSL...
Cant find power button
here's a link to a page with a diagram of the buttons above the keyboard and will show you the power button.
http://armbrust.dyndns.org/tips/presario700/700_systemviews.htm
Dec 20, 2007 | Compaq Presario 700 470024-192 Notebook
DDNS
Currently the only DDNS provider that the DI-604 support is DynDNS.org. When configuring these routers to work with DynDNS.org, please use members.dyndns.org as the Server Address.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
David Payne
David Payne
