Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
I HAVE USB EXTERNAL HDD AND ITS MODEL IS WD5000I032-001 AND I NEED POWER SUPPLY SPECIFICATIONS
    Top Expert:
  • 12,223 Answers
You must download the specifications for power supply form your manufacturer suppliers, go to the website and download the owner manual, and get it, with your model, serial number.
God bless you
Posted on Jul 30, 2013
Seatools test code 606060d0 hat does it mean
this code usually suggest that this is lba (logical block addressing) issue, i am suspecting your pcb board being at fault or usb port or usb cable or power source. i assume that this is on external hdd?
asking that sort of the question you should provide manufacturer of hdd, internal or external, what wer the symptoms, what is the size of hdd, what o/s you use, this is helping in providing detailed and correct solution. as you supplied only fragmentary data - only generic solution can be provided.
before you do anything else, check your power supply, check your usb cable and check usb port, check all three on another computer as well.
if power supply, usb cable and usb port are ok, and hdd is out of warranty, then i would suggest opening of the case and connecting hdd directly to the computer via sata cable. and internal power supply.
if hdd works correctly, switch to power supply supplied with the casing, if you can read the data, that way you will exclude power supply as culprit, it works...
that will left only and only pcb and usb port/cable.
hope this short info will help you - do not forget to vote...
Mar 02, 2015 | Computers & Internet
My Toshiba 1Tb External Hard drive Light Isn't coming on!
It sounds like the usb port on the drive itself is shot. You can actually take apart the case and pull just the harddrive out and use a hotswap usb harddrive reader and get to your files again
Dec 11, 2013 | Computers & Internet
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
My usb external Buffalo ministation is not been recognised on my pc and the LED light is flashing green and orange
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
I have a iomega eGo HDD and its not showing up on my computer but it shows up under my devices how do I fix that
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Nov 04, 2010 | Iomega Computers & Internet
Need power cord
According to the Maxtor/Seagate knowledgebase information: your adapter calls for these specifications.
Model: SYS1308-2412-W2
PART NO: SYS1308-2412
INPUT: 100-240V ~ 1.0A MAX
50-60VA, 50-60Hz
OUTPUT: +12V - 2.0A
OUTPUT POWER: 24W MAX.
I Googled the part number and found that several power supply dealers sell this unit.
The Jameco Company sells a power supply with this model number.
I hope this helps you.
Circe D, pctechsonline
Jan 03, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Memorex Ultra TravelDrive 160GB USB Usage
try to buy a high power usb 4port hub>>> using this device it can sustain the power needes of your external hdd so didn't need to plug the two usb cable.... because the purpose of other usb cable on your external hdd is extra power for your hdd>>> so using high power usb 4port hub it can supply power needed to your external hdd>>> you an buy it to the market>>>>>
Dec 14, 2009 | Office Equipment & Supplies
New external harddisk cant be detected on my computer
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Jun 15, 2009 | Western Digital My Book Essential Edition...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
139 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
