Question about GE 30 in. Profile Select-Top JP389 Electric Cooktop
12002125 switch wiring diagram for infinite switch on a jp389 electric stove top.
Electric diagram
You can check the bender with an ohm meter should have about 27k resistance or check the wires with a Billy Meyer see if power is coming in should be 220-240 when the switch is on
Sep 25, 2014 | Kenmore Element Stove Burner Frigidaire,...
How do I replace a broken dual infinite switch on my Amana AKT3040SS ceramic cooktop?
raise cook top out of counter and remove screws holding glass top to base . remove glass and on the right is switch bank two screws holding each / remove and do not pull wires. but transfer one at a time noting that markings on old sw match new . . sw pt # is 12002125 and cost 49.35. and reinstall in reverse.. hope this helps . and do turn off the power before you start. mm good sailing .,
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stove top is throwing sparks & flipping the fuse. Also one burner is either on or off. Where to look first?
I think that one or more of your infinite switches have shorted and need to be replaced.
For an exploded view of the unit check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
For details on how to replace the switches, check out my other posts
Oct 25, 2009 | Jenn-Air JED8430 Electric Cooktop
Heaters won't turn on
I would certainly call GE on this one!
Jul 24, 2009 | GE 30 in. Profile Select-Top JP389...
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
GE 30 in. Profile Select-Top JP389 Electric Cooktop Logo
32 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
