Question about Toyota Sewing Machines
Replace bobbin case
Hi, I have a Toyota 9800 sewing machine, and I'm looking for the bobbin case to replace, search the internet without luck. Where can I get it ? Thanks. Hildara.
    Champion:
  • 208 Answers
Bobbin case should be standard on that machine if it is a side or front loading bobbin case with a finger
Posted on Oct 25, 2013
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 323 Answers
SOURCE: bobbin case pops out wehen sewing.
The case probably has a scratch or a burr on it. Take it out of the machine and examine it for burrs or scratches.If you find some they can be removed with an emeryboard and then buffed with an SOS pad to make it very smooth.
When you put it back in the machine, thread the machine and sew by turning the wheel a few times before you actually begin sewing for real.
sewman7
Posted on Mar 20, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
SOURCE: machine does not sew- it does not catch the thread from bobbin
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not,open the bottom cover with a flat screwdriver, loosen the two 2 mm hex screws, push out and disengage the gears. Adj the hook position by turning left or right so that it is right above the eye of the needle when the needle is on its way up. Tighten the hexes. I also give my machine a good old job with a high grade geese on the gears and light old drop on all moving parts before I close the cover.
Have fun.
Posted on Jan 01, 2010
  • 108 Answers
SOURCE: JcPenney 7064 , bobbin case, bobbin and manual ??
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
I am looking for a metal bobbin holder for a Montgomery Ward UHT J1980 sewing machine.
If you have the original bobbin case that came with your machine, you can take it to a sewing repair shop and check if they can get a replacement. Otherwise, searching the internet:
Bobbin Case Hook And Race Wards Sewing Machine Model UHT J1980
http://www.manualsonline.com/support/montgomery-ward/sewing-machine
Try taking your machine to a sewing repair shop and see if they can help. Perhaps they will try some bobbin cases that they have in stock.
Apr 23, 2016 | Sewing Machines
What size bobbins, my machine is making a thumping noise, brought it to be looked at and they said the bobbin i was using was too small ( he s pretty sure)
What model sewing machine do you have? That will make it easier for us to recommend a bobbin.
ALSO, very important to use the small brush they give you with the sewing machine and clean out the bobbin area of all the dust that builds up. If you do not have the brush with the machine, you need a make up brush or a small think brush that looks like this below. Sewing machine parts are made to fit very closely together and even the smallest amount of dust and dirt build up can make the machine operate improperly and make that thumping noise you heard. Good luck Walter.
yhkpnzmfapa9pgfmvkdthbd2zvb2zfuvwdyozy1tohfmji9bstmxoljulrcjh8hwa8psd5fhwhgjjaaf+pf9lgy3ofgtogf+r3sregyp5uwct3zfvpkjp5ebsj3lawnwwrzl+obxwotflarbfv5lax4eh9i0txovlle1ifj1apfrfllo7auyprtuaaaaasuvork5cyii=
Apr 14, 2016 | Sewing Machines
I can't figure out how to thread the bobbin into the case
Difficult to assist without knowing the make & model.
Best advice would be to consult the owner's manual or search the internet for bobbin threading instructions/videos.
Feb 12, 2016 | Sewing Machines
I have a 2013 Singer one plus that I bought less than a year ago. My bobbin case keeps locking up. After I take plate off & take out bobbin case then put back in correct position & sta
Could be that your bobbin thread is wound too tightly and having a problem pulling thread from it. Try setting the pressure on bobbin a bit less and that may cure it.
Sep 30, 2014 | Singer One Plus Computerized Sewing...
Noisy bobbin bounces in case
If you just had serviced a month ago I would take back and tell them to fix the problem you did not have before they serviced it, or try calling maybe then can advise over the phone.
Jul 17, 2017 | Sewing Machines
I can't wind the bobbin tightly enough on my sp10 toyota sewing machinene
it's possible that the machine has a internal problem & that's why you can't wind a bobbin, or it could be warped, the machine needs to be serviced
Mar 06, 2012 | Toyota Sewing Machines
Looking for bobbin case for singer 3270c I see lots that look like the one I have but none of the numbers they list match mine... Also the machine is bunching up the tread and my bobbin case is broke so...
check with these 2 websites for the part ,,
sewingpartsonline.com or sewvacdoctor.com
it's possible the bobbin case could be a problem, I have 2 sewing machine & if one of them had a broken bobbin case I would replace it
have you tried a new needle
also check the thread take up lever, if the thread comes off of it, that can jam up the machine as well, I've had that happen before
also keep under the needle plate area clean of lint or loose threads & also the bobbin area
Aug 14, 2011 | Singer 3270 Mechanical Sewing Machine
I have an old 9800 that someone gave me but the thread is not catching and pulling the bobbin thread whilst sewing so the stitches just dont work , hope this makes sense
I have a Toyota 9090 and when I got it I had to replace the bobbin case as it wouldn't turn properly and kept popping out. Have a look to see if it is worn, there should be a kind of tiny metal brush on it. I'm not sure what the brush does but the original bobbin case on my machine didn't have it as it must have fallen off or become worn away. Maybe it helps grab the thread?
I got mine from this site:
http://www.aisin.fr/-c-44_58.html?page=1&sort=3a
The postage was quite expensive, almost the same as the part itself, but well worth it as my machine works perfectly now!
Hope this helps!
Oct 18, 2010 | Toyota Sewing Machines
Sewing Machines Logo
74 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
