No picture have sound timer light blinks .when you turn TV on lamp light come on. Goes off. Tv have sound for 10 min TV cut off type 62" Mitsubishi dlp
    Sergeant:
  • 171 Answers
How old is your TV set ? if you have not replaced the lamp in 2-3 years that is most likely the problem and need to replace that part.
This lamps now run from $40.00 - $90.00 depending on quality.
Posted on Jul 30, 2013
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
tlm931
  • 273 Answers
SOURCE: TV will not turn on
Hello
the most common cause is the DM Module
there are capacitors that need to be replaced in the supply circuits
this is not a easy task and should be handled by some one that has experiance with this i would recomend finding a compatent servicer in your area that is capable and expect to 250 to 325 as a cost
the moduel can be exchanged verses repair but it exchanges at around 745.00
so its recomended to repair and your set should return to normal
Posted on Jan 08, 2009
  • 25 Answers
SOURCE: JVC 62" tv cut off and won't turn back on. red light blinking?
rob52078 is right on the money. You need a new lamp. I usually reccommend getting lamps like the TS CL110UAA for dlplamps.com
Posted on Apr 16, 2009
  • 64 Answers
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Posted on Aug 01, 2009
  • 14 Answers
SOURCE: blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Posted on Dec 17, 2009
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Turn on tv...green lamp blinks several times.lights up but no picture...press any remote button timer in green blinks...tv turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Mitsubishi 62" dlp wd-62525
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Green Timer lights blinks for about 10 sec. Then Lamp light, then nothing
Definitely sounds like a power supply problem. Check with your local TV repair/service center about getting it repaired or replaced.
Dec 19, 2007 | Mitsubishi WD62627 62" HDTV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
