Question about Garmin StreetPilot c340 GPS Receiver
Wont turn on in car - works when plugged into usb on pc...
Take the top face out and you will see the reset button underneath. Press it and will solve your problem.
Posted on Sep 10, 2007
SOURCE:
Just bought a garmin drive 50 changed the language and the turned it off tried to turn it on and it wont switch on
Install Garmin Express from Garmin. Plug your GPS into your computer. Your GPS should turn on into usb mode and Garmin Express should identify it and show you any updates available. If the GPS does not turn on when you plug it into your PC, then contact Garmin for warranty work.
Apr 05, 2017 | Garmin GPS
Jensen smpv 4gbs
Teneale,
I tlooks as if possibly you might have a defective unit. I did some research and you wouldn't be the only one. Either that or maybe try a diffrent USB port, maybe even a usb to wall outlet charger....see if that works. If not I would say its defective.
Jan 02, 2014 | Audio Players & Recorders
Tablet wont turn on
Try to charge it by the original adapter as the PC USB output is not power full enough to supply charging for it
Apr 29, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
USB ports wont work
when i turn on my projector and laptop, the screen on wall says searching. how do i correct
Jan 12, 2010 | Acer Aspire 3000 Notebook
My external hard drive wont conect to my computer.
Is this a new drive? has it worked before? the usual sequence is to connect the external drive to a power source first, and then connect the usb cables to the PC. IF you know the usb cables are good and have verified that they are connected properly, try connect to a different usb port on the PC, sometimes ports go bad. If that still doesn't work, the most likely the hard drive has gone bad.
Oct 03, 2009 | Computers & Internet
Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Aug 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
My PC wont recognize my sciphone I68 dual sim via USB Cable.
Insert the plug let it finish not reading it. Restart your computer and it should work just fine.
Jul 12, 2009 | Dual Electronics CECT P168 Cellular Phone
Pc wont turn on
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Also check the condition of the USB ports if it doesnt work and the fuse. If this doesnt work then I would recommend a repair.
Jan 19, 2009 | Computers & Internet
Need help!!!
will not turn on regardless of plugging it into the charger or the computer
Aug 21, 2007 | Memorex MMP8565 MP3 Player
Garmin StreetPilot c340 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
