Wfs1072aw Hi. My washing machine red light came on saying clean pump, I did all that and made sure all pipes are clear. But still won't and the won't Drain away. Will I need a new pump.
  • Washing Mach... Master
  • 744 Answers
try following this video it's on a bosch but basically the same
Posted on Jul 30, 2013
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
gregory_91
SOURCE: front loading whirlpool machine WFS1072AW which needs pump clean
WFS1072AW has a clip in panel at the bottom across the front.
Removing this will reveal a black plug on the right.
Unscrew this and water will gush out along with (hopefully) the offending coins.
Posted on Sep 06, 2010
gregory_91
SOURCE: I have a whirlpool WFS1072AW washing machine. a
The WFS1072AW has a clip in panel at the bottom across the front.
  • 29 Answers
SOURCE: changing pump on whirlpool washing
take your new pump back and look in the paper for someone who sells used washers and call to see if they have the part u need,they getthe washers for free to remove may have what u need
Posted on Sep 18, 2011
ercupa190
  • 12223 Answers
SOURCE: Whirlpool Washing Machine won't drain after pump is cleaned and there are no blockages
see the causes and remedies:God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Posted on Jul 19, 2012
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Changing pump on whirlpool washing machine WFS1072AW. I need a new pump (so I've been told as the single part isn't available for sale) as I've broken the black screw/cap that seals the pump. I...
Sep 17, 2011 | Whirlpool Washing Machines
Where is the filter in my wirlpool washing machine model no. wfs1072aw and how do I clean it
Hello, Erica.
Your washing machine's filter is located behind the kickpanel (or, 'plinth', as they call it in Oz) underneath the door. First, unplug the machine (or otherwise disconnect it from electricity. To remove this panel, grasp it on both sides and press downward and tilt it forward.
The filter is to be opened slowly as water will come out. Tucking a towel underneath the drain may help. The filter unscrews counter-clockwise. When you get it open, check that the pump is spinning freely. Also, if your machine is not draining, a coin or something small may be blocking the drain pipe (a US quarter or Australian fifty cent piece is a perfect fit to totally block the pipe).
When you are done, add 1 quart (liter) of water to the detergent dispenser.
You can read all of the instructions for this (on page 11 of the .pdf download) here:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001
Enter your model number in the box.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Whirlpool Washing Machines
Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Mar 09, 2010 | Whirlpool Washing Machines
Front loading whirlpool machine WFS1072AW which needs pump clean
Feb 13, 2010 | Whirlpool Washing Machines
I have a whirlpool WFS1072AW washing machine. a red light comes on to clean pump. I am not sure how to do it
Jan 07, 2010 | Whirlpool Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
