Light not working .how to fix - Audio Players & Recorders
    Top Expert:
  • 12,223 Answers
Try all this and fix it. God bless you
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the click wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, the battery must be replaced.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board.
Bad click wheel connection
If the click wheel is not seated correctly, it is possible that the iPod will not boot. Be sure that the bar on the click wheel is completely flipped down to ensure a positive connection.
Posted on Jul 30, 2013
Plate light does not work, but lights are good and sockets seem good
check bulb the number plate light runs on the same circuit as the side lights so if they are working its got to be a bad earth on the plate light
Jan 24, 2016 | Cars & Trucks
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
How do i get the insturment cluster and tail lights to work on my 98 accord?
you have to check the fuses to fix the instrument lights and check the switch in the top of the pedal brake for fix the tail lights.
Jan 23, 2015 | Cars & Trucks
Have a 97 honda. Just purchased. It has a toggle switch installed that works with original key ignition. That said... toggle controls whole electrical..everything works..except tail lights,and the dash...
So If I understand, you turn on toggle and then use key to engage starter? Do brake lights and turn lights work, just not the running lights? Or are all tail lights dead. If none work, juice is not getting to the headlamp switch. Best fix would be to replace the probably bad ignition switch and repair wiring back to original, but quick fix would be to run a second wire from toggle switched side to the headlamp switch +
Dec 18, 2014 | Cars & Trucks
2001 impreza Abs light on and cruise control not working
From what I have read the flashing cruse light is to get you to fix the problem. Any cel will throw the cruse light and cruse will not work. Get your abs checked out and cruse will work again when fixed.
Mar 30, 2014 | Subaru Impreza Cars & Trucks
My brake lights don't work but all other lights do
does the brakes lights come on when you step on the brake padel? or do they just work when you put on the head lights. ? what did they fix?
Feb 03, 2013 | 1997 Mercury Mountaineer
Reverse lights do not work, and the licsence plate
Someone has fixed your wiring. Fix it back and the light work as they should.
Oct 03, 2009 | 1994 BMW 3 Series
122 people viewed this question
 Grubhead
Grubhead
