Question about Dyson DC39 Animal canister vacuum cleaner
Turbine head Dyson DC39
Turbine operates inconsistently. Does not always stay on after switching
4 Suggested Answers
SOURCE: turbine head of my Dyson DC08 does not spin
This response is likely too late coming, however for others the problen appears to be the same as the fault with my turbine head which was that the turbine fan had become loose on its spindle. With no pressure on the brushes, friction would allow the fan to turn and drive the brushes via the belt. The faulty part is not available separately however I have repaired mine using araldite glue. Other things to check is for a worn belt. Cheers.
Posted on Apr 28, 2010
  • 53 Answers
SOURCE: my dyson dc17 amimal's main turbine head is not
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
Posted on May 31, 2010
DysonInfo
  • 107 Answers
SOURCE: hi how do you dismantle the head turbine for the
There are two (or is it three) plastic screws on the underside of it. This allows it to be partially split so you can clean the area around the brush roll.
To strip it further needs a Torx T15 bit, but I don't advise doing that unless you know what you are doing and are confident about the re-assembly.
Cleaning around the brush roll area is all most people need to do with these and that is a simple matter.
Posted on Jan 21, 2011
Turbo head has stopped spinning
Hi Fay, it's Jack at Dyson.
If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 05, 2016 | Dyson DC39 Multi floor canister vacuum...
Brush bar doesn't spin on dyson on dc39
Hi there, it's Jack at Dyson.
DC39's Trigger head floor tool is powered by a turbine, driven by your vacuum's suction. Following these simple checks should help you resolve any issues which could be preventing the brush bar from rotating as normal: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar/dc39-check-triggerhead-tool
If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
Feb 24, 2015 | Dyson DC39 Animal Canister Vacuum
Get the brush bar to spin again on my dc39 vac
The rotating brush bar inside DC39's Triggerhead floor tool should rotate when the vacuum is running, unless you turn it off using the button on the wand handle. If it's not rotating, our Support guide will walk you through the checks needed to resolve this: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar
In the unusual event that these checks don't resolve the issue, please contact our experts directly so we can help you further. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 13, 2015 | Dyson Vacuums
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
Why does the brush on my dyson 39 not work
Hi Anne, it's Jack at Dyson.
If your DC39's brush bar won't rotate, but you're confident your vacuum has strong suction, we'd be keen to take you through some further troubleshooting checks when you have your machine to hand. If we can determine that there's an issue with the Triggerhead floor tool itself, we can confirm if we can replace this for you under the free Dyson parts and labour guarantee.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Dec 01, 2014 | Dyson Vacuums
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
Apr 07, 2014 | Dyson DC39 Animal canister vacuum cleaner
Brush no longer spins
Apply some Oil or crease in it to lubricate it! it will surely work
Mar 09, 2014 | Dyson DC39 Multi Floor Ball Canister...
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson DC39 Animal canister vacuum cleaner Logo
104 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
