Fisher paykel gw 709 au
The machine cuts off in mid way washing. All the power on the dash board went off and i cannot switch the power on again. I took off the panel pad control where the power button but when I plug it on the power still cannot be turn on. I drained all the water and took the barrel off to clean. I also cleaned the plastic tumbler. Nothing seems to stuck. I tried to put power on but not successful Regards Joe
  • 1550 Answers
SOURCE: Fisher Paykel GWL10US Washer won't spin
It looks like it has to be the control module.
You need to replace it .
It will cost you around $200 .
Posted on Oct 16, 2008
  • 22 Answers
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Posted on Oct 20, 2008
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. for other fix it tips on FPaykel.
Posted on Oct 21, 2008
SOURCE: Fisher Paykel GWL10US won't spin
if the pump works fine in diagnostic mode then it has tobe a module problem
cheers grant
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
Fisher and Paykel Washer GW 609 when switched on at wall keeps pumping
The best bet is to have an authorized serviceman test the control board for continuity. It is out of phase and cannot reset to the normal start position.
Feb 27, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at
Sep 08, 2012 | Fisher and Paykel Washing Machines
Where is the master overload breaker on a Fisher Paykel WL26CW1 washing machine?
if it was left switch on at the wall when the power came on again it probably blew the computer board due a current surge
Feb 15, 2018 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher and paykel GW 709 balance switch
The electronic boards are the cause of most problems, the main thing is the boards condensers drying out and aging. Resistors, transistors, and micro processors do not give much trouble. The secret is buying an old machine that is still working and removing the electronics board (and other parts) and sticking it into your machine. i would say this will fix the problem(s). Other faults, like valve solenoids generally speaking don't cause problems - but be aware they can, make sure the belts are not worn or some foreign object is jammed in the water pump which may fry the electronics board.
Nov 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
