Samsung SmarThru 4 for windows 8 - Office Equipment & Supplies
Samsung scx-4521 all-in-one. Can print a test page that indicates I am connected to my Window 7. However, I am not able to print from internet. I have used the original install disc but will not install...
What version of W7 do you have, 64 or 32 bit? Did you chose the right version of software/driver? Please post here the error you are getting when SmarThru failed to install. Dan
Sep 22, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My printer is Samsung SCX-4100.. The software SmarThru is not compatible for Windows7.. Do you have any software compatable so i can perform scanning..
for scanning you can use every program that supports scanning (irfanview is freeware, ABBY finereader and many others). You can try new version of smarthru (for samsung SCX 4300).
pifonski
Feb 25, 2011 | Samsung SCX 4200 All-In-One Laser Printer
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
Dec 22, 2010 | Samsung SCX 4200 All-In-One Laser Printer
How do I turn on the scan function on the Samsung SCX-4300?
Good Day Sir, Your machine offers the following ways to scan an image.
  • From TWAIN-compliant software: you can use other software including Adobe Photoshop.
  • From the Windows images Acquisition (WIA) driver: Your machine supports the WIA driver for scanning images.
  • From the Samsung Smarthru software: launch Samsung Smarthru and open Scan to begin scanning.
Have a nice day!
Apr 06, 2010 | Samsung SCX-4300 Monochrome Laser...
When trying to fax using Smarthru 4 from Outlook windows reboots(critical error, I think), I don't think it is windows, It has done this on 2 machines now, any idea what might be the problem ?
you can download the new Driver and Software from below mentioned link and try.......
and check any virus attack in your machine....
http://www.samsung.com/in/support/download/supportDownMain.do
Feb 23, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
Jan 15, 2009 | Samsung CLX 3160fn All-In-One Printer
Problem in Samsung SCX-4200
i have installed smarthru 4 for my scanner but it still dont work. need help
Aug 20, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Network scanning Samsung CLX-3160FN All-In-One Printer
You have to start Smarthru 4 and use it from there. First you have to find the scanner with Smarthu then scan. Play with Smarthru and the settings in it. It took some playing with it for me to get it set right. Now it works just fine.
Feb 27, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Smarthru icon blinks in taskpanel
IF the fax is working (if not, the problem is in the machine...), try to remove the installed printer driver, and download a new driver and install it. How to remove the driver: (1) Close the SmarThru engine and SmarThru program that are running. (To close them, place your mouse cursor on top of the icon located on the bottom-right corner of the desktop. Right-click the icon and choose Close.) (2) Go to Start -> Program -> Samsung SmarThru -> Select 'Remove SmarThru' (Windows 3.1 users: Go to Program Manager -> Samsung SmarThru -> Select 'Remove SmarThru') (3) If you wish to remove the item, select it and click 'Next'. (4) If you wish to select the back-up option, select the item, click 'Finish' and reboot your computer.
Dec 22, 2005 | Samsung SF 5100P Laser Printer
360 people viewed this question
k24674
jasbo
jasbo
