Question about Siemens Bosch Neff Integrated Fridge Freezer Door Hinge Kit Genuine 481147/43033
K9625XOGB/31 Hoarfrost forms on back wall of Refrigerator but is not thawing automatically. What is causing this and how can I solve the problem please?
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
GE top freezer fridge forming ice on wall of freezer
Hi the thermostat could be the cause of your problem but check the temp of the compressor put your hand on it and it should be about room temp any hotter and this needs replacing also look on the pipes at back where they run on the outside check as much as you can and see if it has any frost on any of these pipes.
As its forming on one side then it might not be thermo but check compressor first and make sure its not running hot ok then get back to us
Apr 26, 2008 | GE Hotpoint Top-Freezer Refrigerator
Ice forming on back wall of freezer, not making ice, not getting air flow to refrigerator
Thaw out the evaporator and check your defrost heater for continuity. Check you bi-metal thermostat for signs of swelling. The bi-metal has to be @25f before continuity can be confirmed on it.5051637.jpg Check your defrost timer or adaptive defrost control if the heater and bi-metal check out. Notice the bi_metal mounted upper right hand corner. It opens and kills the heater once the temp gets hot enough to melt the frost.(50f)
Jun 01, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator Making cold air, but not keeping food cold/frozen
Either defrost timer or Refrigerator thermostat, both located in the ceiling of the refrigerator, can give you long enough off times to actually cause thawing and then refreezing. Feel the rear wall of the freezer, half way down to see if a layer of frost has formed on it. This can indicate a problem in the defrost system which has three components.
The only way to be sure which of the two components is the cause would be to catch it in the thawing phase (not running). Tapping hard on the refrigerator temperature control knob can make it come on if it is the source of your problem. Good Luck
Aug 22, 2009 | Whirlpool ED2GHEXN Side by Side...
Refrigerator keeps freezing up
check the door gaskets on the unit they could be leetting in too much moisture and that will cause the unit to form too much ice,
Mar 26, 2009 | True TSSU-27-12M-B Commercial Refrigerator
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Kitchen Aid Model KBLC36MHS01
The drain under the evaporator is frozen/plugged.  You can take the back panel inside the freezer off and run hot water down it to thaw it out completely and this will solve your problem.
Oct 17, 2007 | Refrigerators
Refrigerator and freezer are warm (Kenmore model 59676509500)
if there is frost on the back wall of the freezer than its iced over (the automatic defrost cycle has failed) turn off the fridge for 18-24 hrs with freezer door open and the ice will melt and it will begin to cool again. It takes a long time for the ice behind the back wall to thouruoghly melt, if it isnt all the way defrosted you will end up with soild ice insead of frost and that will take even longer to thaw Dont forget to rate my solution as solved if I accurately answered your question...Thanks!!
Oct 01, 2007 | Refrigerators
Siemens Bosch Neff Integrated Fridge Freezer Door Hinge Kit Genuine 481147/43033 Logo
42 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
