F8 firmware 1013.zip
This is the firmware upgrade zip file for Samsung LCD LA46F81BX.
Mabikire
  • 47 Answers
SOURCE: upgrading with zip
  1. Unzip the file to folder in a location you know
  2. Check the files if they have a set up application file then run it
  3. If they dont have an application file then goto my computer icon right click and selct properties and then select the hardware tag followed by device manager then goto your hardware profile right click your hardware icon and select update then choose option to udate manually and click next and show it under browse icon where the file is located then click next, if your driver is not signed by windows but is from a trusted source click next if the query comes on otherwise wait for clicking finish
  4. Guess what you just did it
Posted on Mar 24, 2008
SOURCE: Samsung yp-p3 firmware upgrade
Place the bin just inside the P3(not in any of the folders) and then disconnect from the computer and power it back on. It will check the firmware and turn on and off a time or two. When it's off and doesn't turn back on power it back on yourself and you're done.
You can check your FW version by going to settings>about on your P3.
Posted on Aug 23, 2009
tvtek
  • 1284 Answers
SOURCE: RCA LCD l46wd22 failed firmware upgrade
You probably want to contact RCA technical support. As far as I know though there is no force that you can do and most likely you will have to replace the main board. Anyway contact RCA technical support. Was there a particular reason you were updating the software?
Posted on Nov 21, 2009
SOURCE: Is there a way to
I have same issue here 37lh50yr . need to update firmware
Posted on Sep 30, 2010
  • 138 Answers
SOURCE: I have a samsung tv
I have only done this once with a tv, but the procedure was to format the thumb drive, and copy the file to the thumb drive. If there is more than just the firmware file on the thumb drive, the upgrade will not work. Try formatting the thumb drive and starting over.
Posted on Mar 06, 2011
How to install upgrade in transcend mp850
Here is a link for firmware upgrade od your mp850:
http://www.transcendusa.com/Support/DLCenter/dllogin.asp?Link=dlcenter'Driver'MP850FWV2.05.zip
After decompressing the .zip file please read the Firmware Update Procedure pdf document. It is described how to do this.
The .zip file contains the .pdf and .exe files too.
Thanks.
gylacz
Jul 11, 2011 | Transcend T-Sonic 850 Digital Media...
My 3600 won't play certain blue ray movies seems to be disney specific blue rays. I don't know what the latest firm ware or driver is or what the solution is to this problem ?
Hello brdog -
There was a firmware upgrade for this player (version 2.15) released on February 25th. Your problem is most likely related to the firmware and the update should solve your problem. You need to visit the following Samsung support page for the BD-P3600 and download both the upgrade file and the upgrade guide:
http://www.samsung.com/us/support/downloads/BD-P3600
On this page, you need to click on the link for 'Firmware'.belectric_165.jpg
This will give you a list of four files. The top two are the update file and the update guide for installing from a USB thumbdrive / memory stick. The bottom two are the same files but for installing from a CD. The update files are zipped and need to be unpacked first then copied to CD or USB for installation on the player.
Please download the relevant files depending on whether you intend to install from USB or CD and then let me know which you are using if you need further assistance. I will be happy to explain any of the instructions in detail, but I suggest you read the upgrade guide first.
Hope this helps. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Mar 30, 2011 | Samsung Televison & Video
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
PLAYER UPDATE REQUIERD !!! PLEASE REFER TO THE MANUAL
All online support for iRiver players is on next site:
http://www.iriverinc.com/lounge/loungeList.asp
note
If you enter an unreadable page: return to / start from the support site above.
Download of the manual
select a category: Manual
select a product: E10
click GO
select: User Manual of E10
Click the zip file in the language you prefer: English.zip for English .
Unzip the file after the download with Winzip or Winrar, to see the PDF file that can be read with Adobe Reader.
Upgrade using iRiver PLUS3 = Download and run iplus3.exe for matching the software on your computer and the firmware on the player
In page top of the support site: click Plus3
Click the Overview | Function | Download to see what Plus3 is and how it works.
Click Download irver PLUS3 to directly start the installation of this program onto your computer
Update the firmware = Download the firmware and run the firmware updater
for putting new firmware into the player
select a category: Firmware
click GO
select: New Firmware of E10
Download the updater zip file
Unzip the firmware updater with Winzip or Winrar and run the execute file to start iriver Firmware Updater: follow the steps.
After a firmware update always run the Plus3 upgrade: to have the correct software on your computer that communicates with the player's
firmware
Aug 01, 2010 | iRiver E10 Digital Media Player
I dont know how to install the firmware for my mp4 i really need help
Do you have the CD for the SMPK8858 ?
Then put the CD into the CD drive or DVD drive of your computer and explore the CD, for the firmware update look under:
\Firmware Upgrade tool\ConsumerUpdate 3.1.2.0\setup.exe
1. explore or double click folder Firmware Upgrade tool
2. explore or double click folder ConsumerUpdate 3.1.2.0
3. run or double click file setup.exe: this will start the installation of the update software on your computer.
After the installation of the setup.exe file, run the firmware update program to start the update for your player.
Most Sylvania players will have a CD provided. When you don't have it, download the driver (a zip file) from Curtis:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_DRIVER.ZIP
After the download unzip the file with WinZip or WinRar:
now look for the firmware installation program under
SYL_SMPK8858_DRIVER \ SMPK8858 \ Firmware Upgrade tool\ConsumerUpdate 3.1.2.0 \ setup.exe
Double click the setup.exe, the same procedure as when using the CD.
There is also a manual for SPMK8858 (a pdf file) online:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_EN.PDF
Jul 17, 2010 | Sylvania SMPK8858 MP3 Player
How do i restore deleted games to my samsung p2?
Games for the YP-P2 can be downloaded, see next site:
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP00&prd_ia_cd=03041300&prd_mdl_cd=YP-P2JAB%2FXEU&prd_mdl_name=YP-P2JAB%2FXEU&prd_ia_sub_class_cd=P
Select the Downloads tab and next Firmware.
Under Description look for the word Games. For Win XP / Vista there's
a zip file available (firmware at least upgraded to version 5.08).
Download the zip file "20080717110554593_Games_worldwide.zip":
right click on the file and
next select "Save target as..."
How to upgrade / reinstall the firmware upgrade, go to next link:
http://downloadcenter.samsung.com/content/FM/200905/20090507111626062/SW_Upgrade_instruction.pdf
Manual for the YP-P2:
http://downloadcenter.samsung.com/content/UM/200902/20090205154425203/YPP2J-EUROPE-ENGLISH4.0.pdf
Nov 22, 2009 | Samsung YP-P2 Digital Media Player
May 10, 2009 | Samsung Audio Players & Recorders
Upgrading firmware
Downloading the Firmware Step 1: Before downloading the firmware, make sure that your computer has an active Internet connection. If your computer is plugged directly into the router and cannot get online, disconnect your router and plug your computer directly into your cable or DSL modem. Step 2: Once you are able to get online, click here to go to the WRT54G Version 5 Download page. Step 3: Click Download to download the firmware file. Approx. file size (Zip file): 1.39 MB If you are using Windows XP Service Pack 2 (SP2) and Internet Explorer, you may see a 'Pop-up blocked' message in your browser Information Bar. If so, click the bar and select Temporarily Allow Pop-ups. Then, click the Download link again. Step 4: Click Save in the File Download dialog box that appears. Step 5: In the Save As dialog box, choose a location for the file (like the Desktop) and click Save. The wrt54gv5_fw_1[1].00.6_US_code.zip file will then be downloaded. When the download is complete, click Close if prompted. Step 6: Double-click on the wrt54gv5_fw_1[1].00.6_US_code.zip file and extract its contents to a single folder (or to the Desktop). NOTE: You will need to use a utility to open and extract files from the ZIP file archive. Popular software to use is WinZip®. For information on how to download WinZip®, visit the following website: http://www.winzip.com. You can also use the built-in unzipping features of Windows XP to unzip the contents from the archive. The following (3) files should be available: * wrt54gv5_fw_1.00.6_US_code.bin * Readme.txt * wrt54gv5_ver.txt Upgrading the Router's Firmware Step 1: Plug your computer directly into Port 1 on the back of the router. Step 2: Make sure that the router's power is plugged in. Step 3: Open Internet Explorer. Type http://192.168.1.1 into the Address Bar and press [Enter]. Step 4: You will be prompted to enter a username and a password. Leave the username field blank, and enter admin for the password. Then, press [Enter] or click OK. NOTE: If you are asked for the password again, the router's default password was changed. Try a common password that you might have changed it to. If are still unable to log in, hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. Then, try Steps 3 and 4 again. Step 5: When the router's web-based Setup page loads, click on the Administration tab. Step 6: On the Administration page, click on the Firmware Upgrade sub-tab. Step 7: On the Firmware Upgrade page, click Browse. Browse to the location where the firmware files were extracted, and select the wrt54gv5_fw_1.00.6_US_code file. When the file is selected, click Open. Step 8: Click the Upgrade button on the Firmware Upgrade page to start the upgrade. The upgrade will take a few minutes - please do not unplug the router's power cord or make any changes during this process. Step 9: When the upgrade has completed, the following message will appear: "Upgrade is successful. rebooting...." Completing the Firmware Upgrade Step 1: Close Internet Explorer. Step 2: Hold in the Reset button on the back of the router for 30 seconds. After 30 seconds, unplug the power to the router and then plug it back in. This step will ensure that the new firmware loads properly! When you are finished... The firmware upgrade is now complete! You can now use the router's Setup Wizard CD to configure your Internet service and set up your wireless connections.
Feb 16, 2006 | Linksys (WRT54GC) Router
32 people viewed this question
 Grubhead
Grubhead
