For remove C8 error on zanussi LS6 - Washing Machines
2 Suggested Answers
  • 7 Answers
SOURCE: Zanussi LS 14
for remove C8 error on zanussi LS14 you must press on/off and press cycle2 key and you get FAC press cycle2 key again 8 times and you get CFG enter on family of this paremeter pressing ifinity key go to parameter ALR and you get ALR= 1 change to ALR=0 AND FIX THE PROBLEM.
Posted on Jan 28, 2011
C8 SHOWING AND NOT WORKING.I have reconnected the burnt connection on main heating element. Unable to re-set.
C8 - During rinse phase boiler doesn't empty:
  • Rinse pump not efficient.
  • Rinse arms obstructed.
  • Boiler level sensor out of order.
Dado
Feb 03, 2016 | Zanussi Dishwashers
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Zanussi dishwasher LS9 AD/G1 reading code C8 and not working
Dado
Jun 25, 2012 | Zanussi 29 in. LS14 Free-standing...
Warning C 08 how to reset?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
kostas
Jan 26, 2011 | Zanussi 24 in. LS6E Free-standing...
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Code C8 76
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Mike//jzklipper
Aug 06, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Zanussi LS 14
Feb 28, 2009 | Zanussi 29 in. LS14 Free-standing...
Viper LS6
cable serial de pc a viper panduit LS6 o como lo puedo hacer la conexion
Mar 06, 2008 | Panduit VIPER LS6 Thermal Label Printer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
