Pyrox r500 Its an old gas heater and the nob on top wont turn and the ignition button sometimes works, how do i fix it?
  • 221 Answers
SOURCE: heater sometimes ignites and goes out. it repeats
The flame sensor rod should be cleaned, if that doesn't fix it check the combustion air switch. There should be an error code, look for a blinking light and code chart under the filter door.
Posted on Feb 11, 2010
Testimonial: "Thank you I will try that."
roniecon
  • 6826 Answers
SOURCE: Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Posted on Jun 15, 2010
Testimonial: "Thanks for your help. Have located the problem now thanks. It's the gas line. Strong smell of gas outside. Grateful for assistance. "
  • 2557 Answers
SOURCE: i have a problem with a pyrox gas heater that
check too see if pilot is clean and check air ports to pilot could be blocked
Posted on Aug 08, 2010
  • 5 Answers
SOURCE: Describe your Problem i have a quasar vulcan gas
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Posted on Sep 05, 2010
  • 661 Answers
SOURCE: pyrox /vulcan model no 4720006
Hi Chastrix,
Are you follow the below steps to start up your device?
  • First Press the ON / OFF button
  • Then you need to raise the temperature to HIGH so that the heater calls for heat
  • The you will find that within 10 seconds the gas valve will open and the sparkler will function and Also Ignition will commence on a low gas rate and move to high fire after 3- 5 seconds (only if high is selected on the control)
  • Within 5 seconds the flame sensor will prove the flame. 5. The fan will not operate until the fan thermostat switch has sensed temperature rise. This may take 2 or 3 minutes.
  • The fan will then start on a low fan speed and after 3 - 5 seconds move to high speed (if High is selected on the control)
Hope this helps..:)
Let me know in case you have any queries.
Posted on Jul 04, 2011
Have a richmond 6G40-36F1 hot water heater had to turn off gas for another issue, now igniter doesnt spark and pilot wont light
Not to sound silly, but are you pushing the igniter button down hard enough so it snaps? If so, your igniter is no good. Try to light the water heater the old fashioned way by using a match. I would use fireplace matches since they are long enough to reach the pilot light point.
May 27, 2016 | Water Water Heaters
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
I have a Pyrox gas space heater 20 years+ old where the control panel does no work
Honestly. You would be best off replacing it with a new one. The new ones are really inexpensive and most have safety features like auto shutoff when tipped. Not worth trying to repair 1980-1990 'technology'. I out it in quotes because there was no use of technology in those old things.
Jun 30, 2014 | Heating & Cooling
We have aRinnai gas heater and its about 30yrs old ????? we rent. anyway the three buttons on top dont seem to work the first one to ignite wont stay down and the others wont work without this can u help
hold the first button down until pilot lights and thermocouple heats then release slowly if still does not work possible faulty thermocouple lead need gas fitter to replace
Jun 10, 2011 | Heating & Cooling
I have a 300 series Pyrox 25mj gas heater. When I start it, it seems to ignite while my hand is on the start button but once I release after 30 seconds it seems to cut the flow of gas. What could be the...
sound like faulty thermocouple lead safety device this allows gas to flow to pilot and when hot should hold open the gas valve for the main burner if faulty the gas is cut off
Jun 05, 2011 | Heating & Cooling
Have a pyrox gas heater, it ignites ok, but as soon as I release the button it goes out.
Check the thermal couple it may be no good and has to be replaced
Aug 19, 2010 | Heating & Cooling
Jun 15, 2010 | Heating & Cooling
The pilot goes off and on and does not light the burner
ok make sure u turn everthing thing off then wait 5 min then turn the dail that controls the heat on it to pilot light then turn the gas nob to pilot then ignit it once lit wait a few seconds and turn gas nob to on pisition then turn heat dail to were the arrow is not to a b or c cause the gas is to high it will blow it self out
Nov 17, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Have a rheem central air conditioner heater. I
gas valve could be clogged it has a screen in the side of the inlet, check this first if not it could be the gas valve itself,, make sure the gas valve is turned on also, sometimes people turn them off and for get the handle should be in line with the pipe not across the pipe
Apr 27, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
