Question about Stihl Garden
Stihl f545 trimmer
What is the right adjustment on a F545 stihl gas trimmer carbrator
  • Stihl Master
  • 1,807 Answers
H is for the high revs, high throttle
Posted on Feb 27, 2016
2 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: stihl model f545 will start but will not throttle
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
Need amanual for a F545 Lumix.
Why do you need two of them ? Stereography ? If you Google the make and model, followed by the word 'Manual' you should get some results. Fixya does not supply manuals.
May 16, 2017 | Cameras
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
I have an Stihl FS-86 weedeater/ trimmer and it keeps cutting off when i pull the trigger and when it runs for about an hour and gets hot. What could be the problem with it?
I'm pretty sure that there is a problem with the carb., with it being a FS-86 it should be old enough to still have adjustments on the carb. if so I'd start by turning the low (L) side needle out (counter clockwise) about 1/8 turn and see if that helps. If the carb. has no adjustment or only hi (H) then I would change the metering diaphragm on the metering side of carb.. As far as a timing issue it's not, unless there is a problem with the flywheel. on a 2-cycle string trimmer the timing is set were they have the flywheel keyed to the shaft and is non adjustable.
Oct 13, 2014 | Stihl Garden
My poluan weedeater will start with full choke but
it needs to be adjusted... if you don't have the tool you need to get one or take it somewhere
Aug 28, 2014 | Garden
How to sharpen stihl gas power trimmer
Sharpen with a flat file. Its a long process as each tooth has 2 cutting edges. There are companies that will do this properly at cost.
Jul 15, 2014 | Stihl Hs81t 24" Double Sided Hedge Trimmer...
Stihl f545 trimmer
50:1 and use the best synthetic 2 cycle oil .
Sep 07, 2013 | Stihl Garden
FS 46 trimmer problems
I think you mean not getting enough gas when throttled up as never seen one get to much gas at high rpm I fix these for a liveing Sounds if Iam correct by you mean starving for fuel check fuel filter Rebuild carberator
Jun 29, 2013 | Garden
I need a schematic for a stihl carbrator digram
should be a zama cafb...look on the main body of the carb...then the other side...go to this site
http://www.zamacarb.com/prod_lookup.cfm
scroll down to product look up by type...this will be 3 alpha-numeric for instance C1Q (see photo marked first)...so click on that square and take the other side top alpha-numeric (see photo marked second) and will see select model...scroll down till you find yours, click search and it will take to to a break down...
Aug 28, 2012 | Oregon Scientific Complete Carburetor for...
Garden Logo
51 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
