Ariston ar6l65 Hello. All the buttons on my washing machine flash (ARISTON AR6L65 EX). Is that you can make a Gnral reset the machine. I hope that you can give me an answer because I do not have the means to do REPAIRING. Kind regards Christophe D
SOURCE: ariston a1636 washing machine
I have the same problem, did this get solved for you?
Posted on May 18, 2008
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
SOURCE: ariston avxl105 washing machine power
reset button
Posted on Jun 29, 2008
  • 123 Answers
SOURCE: Dishwasher, Ariston LI62, kept flashing on R
hi there.....this usually happens when the base of the machine is full of water.....switch the machine off ....remove the two plactic inspection panels at the bottom of the machine and dry out the base....check that all fittings and fixtures in the main cabinet are secure and not leaking..particularly the transfer tube from the wash pump to the upper spray arm..(machine needs to be pulled out of its position to check this as it is at the rear)
regards Sir Galahad
Posted on Aug 18, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
The door of a AR6L65 washing machine italy is permanently locked and doesn't allow any function
Most washing machines, do have an emergency door opener. For that you should read in the manual. Sometimes you have to press a little os small key in a hole, Most of the time on the back side. But every machine is different and I don't have a manual of the AR6L65.
Jun 24, 2014 | Washing Machines
Door continuously locked with a red flash of a AR6L65 Italy
sounds that either it has a bad door door switch or a bad relay
Jun 20, 2014 | Washing Machines
How to remove a door switch of a washing machine AR6L65 Italy
remove back panel first then work your way to the front
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston avxl 140
Check that you don't overload the machine. This can happen if the load is too heavy.
Jan 31, 2014 | Washing Machines
Ariston ar6l65
ariston ar6l65
Nov 14, 2013 | Washing Machines
AR6l65
Could you please describe the problem you are having a little better?
Nov 20, 2012 | Ariston Technologies Washing Machines
Washing machine will not spin
hello, there could be couple of things wrong is the pump draining properly if ok then it may be the module control board some times the transistor on the board shorts out hope it helps
regards
shaun
Jan 08, 2011 | Ariston Technologies Ariston AWD12 Front...
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
