Question about Palm Treo 650 Handheld
Like dead i was charging it one night and there's the orange light that lights up when the charger is plugged, then as time passes it turned green meaning it was fully charged, when i was about to use it come morning time it was not responding, i tried plugging it again to check if the charge is not enough, then the orange light does not light up anymore, i tried removing the battery and inserting it again, and nothing, i'm not sure what else to do...i also tried resetting it, still no reaction...what must i do? thanks
    Problem Solver:
  • 11 Answers
Could be the power connector on the bottom is worn out. I have sent mine back to Palm to have this repaired, it seems to be a common problem at the moment this question has nbeen posted a lot recently
Kevan
Posted on Nov 22, 2007
SOURCE:
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
When i but the battery in the charger the orange and the green light comes on and i left it in for a long time and the battery was only charged a little bit whats wrong
This has happened to me. The transformer in the charger is dead.
you can test the charger by plugging it in and using a multimeter to test for current.
if you get nothing, it is dead.
You will need to get a new charger pack.
Apr 24, 2010 | Water Heaters
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
I got a Peg Perego Charger when I plug it into the battery no light comes on at all. Does that mean the battery is completely dead?
Not necessarily. There should be some type of light on the charger- green means charged, red or orange, not charged.
If no light comes on, it's the charger.
Jul 11, 2009 | Peg Perego 12 Volt Rechargeable Battery
Dead laptop
Does the green light on the charger turn orange when you plug it in? Because it might have been that you didn't actually charge it. The metal ring around the charger tip sometimes gets bent so that it doesn't make good contact. If you aren't getting a constant green or orange light when you plug it in, you might not be charging it at all.
That would be the easy fix. The real problem is probably much greater, because you probably know how to charge your laptop. The laptop doesn't need a battery to run, so if it doesn't start up while plugged in, you have an additional problem.
write back if you find that the simple things didn't work and you need more help figuring out a specific fix.
May 18, 2008 | Apple iBook Mac Notebook
My sidekick 3 wont turn on
heres what i would say. let it charge for more than hr, and this bring it up to speed..if not i believe the battery may be defective, i just experienced this problem last night..the battery happen to be defective, then put another battery after awhile i went to sleep woke up, and it wouldn start...i let it charge for a while and it was good as new
Feb 11, 2008 | T-Mobile Sidekick® 3 Cellular Phone
PSP no power
Try taking the battery out and plugging it into the wall with only the charger and see if it turns on. does The green light came on?.
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
Palm Treo 650 Handheld Logo
185 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
