Question about Watches
Quemex Cuckoo Clock Adjustments
The cuckoo bird comes out 20 mins early
  • 161 Answers
SOURCE: Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Posted on Nov 02, 2008
OhioTrucker
  • 33 Answers
SOURCE: i have an elgin rooster cuckoo clock with serial
Go to google and put in all the information you have. Some times try different ways to ask the question.. Hope this helps..
Posted on Feb 27, 2010
  • 184 Answers
SOURCE: My cuckoo clock dont tick
I had a cuckcoo clock I got when I was in the Navy, and it came from Germany. I had the same problem. Have you ever heard the expression, "Stop yanking my chain"? Well, this is exactly what I had to do to get mine working... Well, since they wind up via the chain...
Posted on Sep 01, 2010
  • 8404 Answers
SOURCE: i just got a Bradford
I am not familiar with the product you have. However, if this is a genuine cuckoo clock, driven by weights, the weights must be "wound", weights pulled to the top of their travel. If this is electronic, I would be looking for a switch. There also may be a electronic eye that prevents the sound at night. Can the eye see the light?
If you just got it, and if my comments don't apply, I am sure a quick call to the Bradford Exchange will solve your trouble, whether it is a step you inadvertently over looked or if the device if fault. I am certain they will help you.
Thanks for your question @ FixYa.com
Posted on Feb 17, 2011
SOURCE: Kaiser clock model kc-2.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Posted on Mar 09, 2011
My clock will only run with added weight on the clock chain. I added the cuckoo bird weight to the clock weight chain and it keeps good time. If I remove the added weight it will stop.
I think your clock needs to be lubricated. A special light weight oil in a syringe will do the job. Just a little bit will Do.
Jun 23, 2016 | Watches
I need instructions for Acctim FELDBURG Cuckoo Wall Clock
Hi, not much info on this clock specifically. This might help though :)
Instructions Quartz Cuckoo Clocks
Jan 31, 2015 | Watches
I just got a radford exchange purr-fect moments kitten cuckoo clock and the clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird sounds unit of th
There are several companies that sell that movement , just google clock movements and they have a chart with spec to match yours. I have replaced several in my time, its pretty easy
Jan 05, 2015 | Watches
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
Timing is off bad on the cuckoo part of the clock. It won't stop and runs till the weight hits the ground.
We had the problem with ours when I was a kid. What we did on ours was to turn the hands until the clock cuckoos. Then we removed the hands from the stem and placed them back at the correct time. Hopefully, you can remove the hands from the stem without a problem. Don't force it however. Good luck.
Feb 01, 2013 | Watches
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
LGC310 mobile phone has a cuckoo chime every hour on the hour, how do I turn this off?
Press the "OK" button then "settings" then "date and time" then "time" then scroll down to "hour indication" and change this to off.
Feb 09, 2012 | Watches
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
kaiser clock
Aug 04, 2010 | Watches
Watches Logo
52 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
