Panasonic TXP42XT50B tv wont switch on - Televison & Video
My Panasonic tv wont turn on after been unpluged
CHECK FUSE IN PLUG FUSE ON PSU IN SET ALSO CHECK THEIR IS NO OTHER SWITCH ON BK SET FOR OFF
Sep 25, 2017 | Panasonic Televison & Video
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
I have a Panasonic TC-P42S30 that wont turn on. I have replaced almost every board and still nothing.
If you have replaced all the boards, including its power and main board, some critical adjustments should be done. The TV wont switch ON, without these adjustments. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 19, 2014 | Panasonic 42 TCP42S30 42 Plasma TV
My panasonic tv wont turn on and led light flashes twice
Our Sony TV sometimes won't come on when the switch on the tv is pressed. Weirdly, if we switch it off at the wall socket, wait a few seconds, then switch it on at the wall socket again, the tv switch then works......
Don't understand why this works, but if it gives you a work-around, it would be a lot cheaper than a TV engineer's visit....
Feb 20, 2012 | Televison & Video
Panasonic Viera TH-46PZ85BA Will not switch on
Yes, the unit has a problem. I work for Panasonic in New Zealand and the unit needs to go in for servicing. 10 flashing lights means a fault has occurred (if I was at work I could tell you what 10 flashing lights means).it should be repairable.
Sep 26, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Tv wont turn on> is there a reset switch?
reset button can apply when the tv turns on. first the tv has a short circuit and has to be repaired in order to be able to reset the tv to the original settings created in the program as brightness, color etc.
your tv now needs a visit to the workshop first, to turn on.
Apr 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
No power
to discharge your crt wont hepl you to switch it on . check the power supply first if they had B+ then check the horizontal transistor
Jan 19, 2008 | Panasonic CT-36HL43 36" TV
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
