Question about Kodak Ektaprint 95 Copier
KODAK EKTAPRINT 95 COPIER I50 ERROR CODE
When I switch on the machine, I am getting I50 Error Code. Can any one help me to clear the error.
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Has a I54 code. goes on but goes into code after 10 seconds or so. Thanks Lawrence
there is a circut breaker switch in the back of the copier put it into (1)
Mar 19, 2010 | Kodak Ektaprint 95 Copier
The copier shuts down when trying to print
Look for the error code, that would lead you to the problem area, most likely the fuser assy. needs to be replaced. Do this, Press;
ADDITIONAL FUNCTIONS,
press 2 and 8 (together),
ADDITIONAL FUNCTIONS again,
You should now be in Service mode, if not hit CLEAR twice then repeat the steps above.
press COPIER,
press ERR
the one listed at the top is the error code.(write it down)
You can try clearing the code then reboothing the machine with the right side switch and it might work.
This is how you clear the code, follow all the steps above except the last one (ERR) instead select FUNCTION above then CLEAR then ERR. Turn the machine off then back on again.
If that does not help and you are still having the same problem, you could either call Canon with a service call, call a local technician or get yourself a service manual and with the error code you wrote down above try looking it up or contact us again with the error code. Good luck.
Dec 18, 2009 | Canon imageRUNNER C3220 Color Copier
Canon image runner error code E000000-0000 solution
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Oct 13, 2009 | Canon Office Equipment & Supplies
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
If this service costs please cancel this request immeditately. Thank you. I have a Kodak EKTAPRINT 95 Copier that has an error code E37 can you help solve this problem or tell me what it means?
GO ON LINE , TYPE IN ADDRESS BAR
KODAK CORPARATION
PICK USA
ASK QUESTION WHAT TYPE OF HELP YOU NEED
TECH SUPPORT,
CUSTOMER SERVICE MY HELP
LOCAL KADAK DEALER SALE THAT PRODUCT
CANDYMANGANDY
Jan 28, 2009 | Office Equipment & Supplies
Kodak ektaprint 90
Hello tldant,
Wow, that is a very good copier although quite old.Unless the wheels have been run off of it its a keeper. I used to work for Kodak when they marketed this machine and I was a service tech for them. Great machine. I had one that had 6 million copies on it and was still worth keeping. Now to the point. Unfortunately this copier has a physical "jumper" inside the back panel that has been removed which causes the copier to expect some type of additional action to provide access to the device. There were several ways to gain access (access codes, external controllers, even a card like a credit card) to the copier once this jumper was removed. The jumper is actually a small connector that fits on the end of a wiring harness that basically completes a circuit to tell the copier to be ready. Without the jumper, the copier is waiting for an external device or virtual device to "complete" the circuit. It has been over 10 years since I touched one, so I am sorry that I can't recall the exact location of the wiring harness. However,typically the "jumper" (a small connector with a mere loop of wire from one pin to another) is tied near or onto the place it belongs. So I guess my point is that the copier is worth the time it would take to remove the covers and inspect the wiring in hopes of noticing a stray connector that is just dangling. I wish I could be of more help, but maybe I have been some help. Take care and good luck. :-) ................spinal........
Apr 15, 2008 | Office Equipment & Supplies
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error Code E005
Have to reset the cleaning web counter and error. Press *, 2&8, * to enter service mode. (*28*). Highlight COPIER, select COUNTER, select MISC. select CLEANING_WEB and press C on the keypad to clear the counter. Press reset to get back to main service menu, highlight FUNCTION. Select CLEAR. Highlight ERR and press OK. Switch machine OFF/ON. Hope this helps, let me know?
Sep 04, 2007 | Canon NP 6050 Copier
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
