Class rolls how do we get our class roll
2 Suggested Answers
jasperoni
  • 203 Answers
SOURCE: Passenger side window in 1997 E Class Mercedes
i m assuming it is your right rear window. it is the most common to fail on that model. I would remove the door panel and inspect your window regulator. the drive cable probably broke. You can disconnect the window from the regulator and manually slide it up and prop it in place with a piece of wood. that's what I did when I did roadside for benz. Hope i have been helpful
Posted on Jun 28, 2009
Can't get my back windows to roll down?
DOES THE ROLL DOWN FUNCTION WORK FROM THE DOOR CYLINDER WITH THE KEY?HAVE ANY FLUIDS EVER GOT ONTO THE SWITCHES?DO THE LIGHTS DIM SLIGHTLY ON THE DASH WITH KEY ONBUT ENGINE IS OFF AND THE WINDOW SWITCHES ARE DEPRESSED?IF THEY DO ITS DRAWING CURRENT.CHECK FOR STUCK GLASS OR BAD WINDOW REGULATOR/MOTOR.IF THEY DON'T DIM THEN CHECK FOR BROKEN WIRING OR POOR SWITCH.
Jan 06, 2012 | 1997 Mercedes-Benz Mercedes Benz S Class...
I was driving and my car lost all power and won't restart I've been told the engine is seized solid and the timing chain is broke and that's why it wont work but the wheel's didn't lock...
I assume your S class is an automatic gearbox ,hence the roll to a stop when engine seize/cam chain break.the symptoms of a camchain break would be the valves will hit the pistons causing major damage to valves, pistons,cylinder head, conrods, bores and possibly crank.Its possible that the engine seized first causing the chain to break,either way it would be a seriously expensive/terminal engine problem.
Jun 01, 2011 | 2001 Mercedes-Benz S-Class
When the roll of black thermal material is used up, how do you get it off the finished roll? Is there a way to reverse the direction of the feed? How is that done?
grab the roll and at the same time, squeeze and pull toward you. The take-up spindle will collapse slightly and the used ribbon will come right off.
Hope that helps !
Apr 09, 2010 | Datamax M-Class 4208 Thermal Label Printer
I own a 1995 mercedes SL500 and recently started having trouble with the left front door window. While stopped in a construction zone, I rolled both windows down. After leaving the construction area, I...
The window position is monitered by the softop control module. It sounds like the glass is very dirty and drawing too much amperage during window operation. The soft top is electro hydraulic. The roll bar is operated normally with hydraulics but it is mechanically released in an emergency situation. 1st make sure your windows are clean and the express(one touch operation) is working-the soft top will not function properly if the windows are not synchronized. Next be sure your roll bar works-hold swith in up position to lock roll bar rams in if they have been deployed. next put your top all the way up. untill windows roll up and try it with the engine running and trans in nuetral- if it still does not work mechanically secre rear of top with tool provided in your tool kit the owner's manual will tell you how to do this. good luck
Jun 19, 2009 | 1995 Mercedes-Benz SL-Class
2000 ml320 transfer case squeaky noise
hi,better to bring your car to gas station with car lifter,lift your car ,you can determine where the noise come from,or maybe you can see the rotation of your proffeler shaft,ty
Apr 05, 2009 | 2000 Mercedes-Benz M-Class
Big problem
The only thing i can suggest is pushing the film rewind button on the bottom of the camera body. crank the film back in to the canister and drop a new roll in. Ihave experianced this problem once or twice when I rolled canisters from bulk film and it would get jammed.
Good luck
Jul 06, 2008 | Nikon FM10 35mm SLR Camera
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
