Question about Marantz RC3200 LCD Touchscreen Remote Control
Touchscreen not working
Every thing works except touchscreen
Is it possible to replace or repair the touchscreen?
Possible but may not be cost effective. Internet search for the part number on your screen is your only hope on this one.
Apr 19, 2016 | Kenwood Dnx9990hd 6.95" Touchscreen...
How do i find out if my laptop is touchscreen compatible
You need the model number - the COMPLETE model number. Be advised though, that there is no such thing as a "touchscreen compatible" or "touchscreen ready" laptop. That would assume that the touchscreen hardware is already there and all you need is the firmware or software to make it work. Not gonna happen. Touchscreens are much more expensive that regular ones and manufacturers are not going to put them on and not activate them. Either you got one or you don't. Dell, for example, makes some models both with and without touchscreen. The only difference is one letter in the model number.
Mar 12, 2015 | Computers & Internet
Whirlpool gh6177xpb microwave error 252 on touchscreen at startup. How do I fix
clean ribbon cable that goes from pad to control board with denatured alcohol undo lock unplug cable clean contacts
Nov 23, 2014 | Whirlpool Microwave Ovens
Touchscreen problem
The connector for the screen (digitizer) may not be connected properly. Return to the place that did the service, and ask them to check the phone again. This issue may be related to their work.
Oct 18, 2013 | Cell Phones
replace batteries , and clean contacts batteries very well.
However if toruchscreen not work, you must open the r.control and clean the keyspads very well from oxide,etc use contacts cleaner and fix it. Try again.
If the problem persist, you have a Syscom faulty.
God bless you
Jul 30, 2013 | Marantz RC3200 LCD Touchscreen Remote...
Touchscreen doesn't work. It happened suddenly. Garmin nuvi 255
try recalibrating the sceen. to access, turn unit on but hold power switch to the left until touchscreen config shows (35-60 seconds) follow prompts onscreen
Mar 19, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Touchscreen won't work on i9 phone i just bought it
it may be that your sensitivity level is to low on your phone try changing it in the settings menue
Jan 08, 2009 | Cell Phones
My touchscreen wont work
switch off and lev for haf hr and restart it wil workk
Nov 11, 2008 | Apple iPhone Smartphone
Help with my hp tx1000 please
Mine has already twice made the same thing. Solution was simple - got the touchscreen changed (luckily under warranty). As third problem required change of the motherboard, I'm planning to get rid of the piece of junk alltogether. I think it is a solution for all the troubles with tx1000.
Jul 01, 2008 | HP Pavilion TX1000Z 12.1" Touch Screen...
Marantz RC3200 LCD Touchscreen Remote Control Logo
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
