Question about Dell Computers & Internet
Dell laptop not turning on
I was giving a dell laptop with no battery and i know you can still use them when they are plugged in but this one will not turn on and the blue light will only come on for a sec and than it turns off
    New Friend:
    Problem Solver:
  • 14 Answers
Check all the USB ports to see if they are damaged. If any of the pins in the USB ports are touching the chasis then this will case a short circuit and stop it turning on. With the power disconnected, move the pins away from the chasis using a small ascrew driver and make suer they are not touching each other.
Posted on Jul 30, 2013
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Posted on Jul 14, 2008
itszspot
  • 4 Answers
SOURCE: dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Posted on Aug 16, 2008
anuragmj
  • 40 Answers
SOURCE: My Dell Laptop is not turning on
Possibley it could be some internal parts. Please try run the onboard diagnostics by holding down Fn and the power button. Make a note of the 3 lights above the keyboard (9,A and the lock key). If it starts for a second and then shut's down, the MoBo will ahve to be replaced. 1501 has known issue and I know this as I work for DELL tech support. Call tech support or chat with them...If the product is under warranty, you should get a replacement.
Pardon my spelling mistakes!!! Let me know if the information was useful or not.
Posted on Sep 17, 2008
SOURCE: gateway ml3108b laptop wont start up
This is a problem with that particular model of laptop.
It seems that the GPU chip (Graphics) overheats resulting in the solder points not making a good connection to the motherboard.
If your quite hardware savvy, you could strip her right down, take of the cooling unit and clean off all the old thermal compound and dust from the Heatsink, CPU and GPU. Then replace the thermal compound with better stuff (Arctic silver 5). This may solve the problem.
I had to do a bit more than this to get mine up and running though. If you need details just let me know.
Better still is if you know someone who's real good with a heatgun (aka Someone who's done this sorta thing on an XBox360) that can reflow the BGA joints on the chip for you. Sounds dangerous i know but if your lappy aint working theres not much else to lose.
Good luck, maddoc666.
Posted on Feb 13, 2009
  • 479 Answers
SOURCE: 1150 dell inspiron. Laptop won't power up. If
This seems an issue with inverter board need to checked by an expert.
thanks
Posted on Jul 27, 2009
Dell laptop latitude 6140 will not turn on
do you know how to access bios if so do a default reset ,save change and exit .
Mar 11, 2015 | Dell Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Had a new battery from Dell,it seems to charge ,but only to 67%. Got this laptop from a good friend who had ordered the battrey from Dell. (he`s reliable,but I figured he may have made a mistake...
I have never heard of the dell BIOS being able to reject a non Dell battery. How does the laptop work when you plug it in? Normally. If you just bought this battery, I would suggest that you return it from where you bought it. The battery sounds defective, like it won't hold a 100% charge more than once? I have had Dell laptops and used compatible batteries on them. Return this battery, get a refund and look for an OEM compatible on Ebay.
See the link below for an ebay page with several battery options, many of them with at leat 1 year warranty. If Deal Extreme does not back it's products, I guess it's not deal.
As far as the BIOS, I again have never heard of that. You can look at your power options at Start, Settings, Control Panel, Power options. This will set power usage for when the laptop is plugged in or when the laptop is on battery.
This situation really appears to be a defective product.
I hope this is helpful, if I can give you any further clarification, please let me know.
Brian
Jan 14, 2011 | Dell Inspiron B130 Notebook
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Jan 06, 2011 | Dell Inspiron 1545 Notebook
Dell Inspiron 6000 laptop periodically shuts OFF
You've checked the p/s and it has volts out. Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone. Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 04, 2010 | Dell Inspiron 6000 Notebook
Describe how to run a laptop without the battery
Simply plug the wall charger in and take the battery out. It should run just fine. I have a Dell Lattitude D630 and do this all the time. I've also done it with other laptops
Mar 25, 2010 | Dell Inspiron 2200 Notebook
Dell Inspiron 1501
Are you using the original charger or another. The Dell power system will give this message when you use a 70W charger on a system that needs a 90W charger - check the sticker on the back. Also, if the plug to the main board gets just a little loose you will get this message. Be careful you are not putting too much strain at the power plug or you will need a repair soon!
Jon
Dec 31, 2008 | Dell Vostro 1000 Notebook
Dell C800 Laptop dies when unplugged
Check the pins that connects the computer to the battery. Something might be bent and wouldn't make contact with the battery. Turn the system on with both the battery and ac adapter plugged in. Press F12 on the Dell splash screen. Go to Page 4 (press ALT-P to move to pages). Check if the battery is detected. If not then the motherboard needs to be replaced.
You can contact Dell Spare Parts dept: 1-800-357-3355. Just give them the service tag of the system so they'll know the part number of the motherboard.
If you think this is helpful, please rate it.
Dec 05, 2008 | Computers & Internet
Laptop died!!!
u got a serious problem with ur laptop:
i duuno how that occur but u got a short circuit problem.
this may solve the problem try to sctratch the nozzles of the battery and the nozzels of the laptop and see what happen
if that not work u need to give it to a repair guy
cuz all the laptops turn on with adpter
good luck
Aug 16, 2008 | Dell Inspiron 9400 Notebook
Computers & Internet Logo
26 people viewed this question
Alun Cox
