Feeding paper roll into EL-2901P - Office Equipment & Supplies
  • 168 Answers
SOURCE: PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Jan 28, 2008
  • 21 Answers
SOURCE: paper feed
If the print-out is an 'alien-like' one, the problem is on the sensor of the printer. The sensor is on the opposite side of the gears. Under the black cover.
Posted on Feb 16, 2008
SOURCE: Changing paper roll on Citizen CX-121 Calculator
At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
Posted on Apr 11, 2008
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SharpCSR
  • 11 Answers
SOURCE: how do I thread the paper tape to the machine
Hello, my name is Curtis, and I am a Sharp Customer Service Rep. What you will want to do is on the back of the calculator there should be a thin horizontal slot that you would feed the paper through, it will only feed so far before it hits a wall on the inside, make sure the calculator is turned on and press the feed key in the upper left side of the calculator, it should take up the paper, if not then give us a call at 1-800-237-4277 or 1-800-BE-SHARP. Hope everything works out.
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    How do you put the adding paper into the machine? My machine is a EL-1197iv
    Never insert paper roll if torn. Doing so will cause paper to jam.
    Always cut leading edge with scissors first.
    1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
    2) Turn the power on and feed the paper by pressing . (Fig. 2)
    3) Insert the paper roll to the paper holder. (Fig. 3)
    DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
    DAMAGE TO PRINTING MECHANISM.
    Jan 03, 2011 | Sharp EL-1197PIII Calculator
    Will not feed paper
    PAPER ROLL REPLACEMENT
    jam.
    (Fig. 1)
    2)
    3) Lift the attached metal paper holder up and insert the paper
    Dec 19, 2010 | Sharp EL-1801AII Calculator
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    Tape wont register on this after we changed the tape
    Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
    1. Lift the paper holder up.
    2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
    3. Insert the paper roll from the left side of the paper holder and make sure the paper
    roll is set in the proper direction (with the paper feeding from the bottom).
    4. Insert the leading edge of the paper into the opening directly behind the print
    mechanism.
    5. Press the paper feed key and feed the paper under the edge of the paper cutter.
    Dec 07, 2007 | Sharp EL-2196BL Calculator
    Sharp EL-2196BL
    mechanism.
    jasbo
    jasbo
