Hotpoint aqualtis aq9l29i
Is it possible to change the bearngs on this washing machine??
noffie
  • 10 Answers
SOURCE: how do you replace a
The belts that come on a hotpoint aqualtis washing machine is a stretch belt there is no adjuster for it but there is a little trick. TO HELP YOU SOLE THIS YOU NEED A BOWL AND A KETTLE. FIRST FILL THE KETTLE WITH WATER THEN PLACE YOUR BELT IN THE BOWL AND ONCE THE WATER HAS BOLIED POOR THE HOT WATER IN IT LEAVE IT FOR 5 MINS THEN TAKE THE BELT OUT BUT BE CAREFUL NOT TO BURN YOUR SELF NOW GRAB THE BELT AND PULL IT BY THE BOTTOM AND THE TOP BY DOING THIS BELT STRECHS ENOTHGH TO FIT ROUND THE FLYWHEEL AND MOTOR ALWAYS HOOK THE BELT FROM THE MOTOR FIRST THEN ROUND FLYWHEEL I RECOMMED WEARING GLOVES WHEN DOING THE JOB KEEP ME INFORMED ON HOW IT GO'S NOFFIE......
Posted on Apr 08, 2008
  • 333 Answers
SOURCE: Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Posted on Nov 30, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
SOURCE: Hotpoint aqualtis giving H20 error
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Posted on Jan 11, 2010
Aq9l29i washing machine bearing
You dont... The replacement part is complete drum with inner drum and outer shell.
Mar 10, 2014 | Washing Machines
Hotpoint Aqualtis 2 months old dial turns without changing the display
machine is under warranty, contact Hotpoint for a service call.
Oct 15, 2012 | Hotpoint Washing Machines
Hotpoint Aqualtis AQ9L29I 1200 9kg washer has stopped working! It was working fine, got up one morning to load up and it wouldn't switch on! Door wouldn't open, no lights on, nothing, dead!...
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 12, 2011 | Hotpoint Washing Machines
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
Dec 04, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
