Question about Konica Minolta Office Equipment & Supplies
C 0211 error code c0211
    Filmmaker:
    Uploaded 5 video answers.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 45 Answers
NEED MODEL PLEASE
Posted on Aug 30, 2013
3 Suggested Answers
  • 214 Answers
SOURCE: Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Posted on Dec 07, 2007
rajdeepdutta
  • 2517 Answers
SOURCE: error code c0211
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Jan 21, 2011
Error code c0211 in bizhub c252
c0211 = Manual tray rise decent error - check PC14 lift up sensor, M2PC tray 2 vertical transport motor and also the tray 2 control board
Aug 15, 2013 | Konica Minolta bizhub Office Equipment &...
C 220 biz hub giving error of c-0211
C0211 indicates a problem with the lift section of the bypass tray on the side of the machine. Checking the connections on the wiring harness would be a good first action. These can be accessed by removing the small hinge panel on the side of the bypass tray. Its only two screws, and you have a very low chance of breaking anything as long as this is the only panel you take off.
Feb 29, 2012 | Konica Minolta KonicaMinolta PagePro 4650...
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
Error code C-0211 Konica Minolta Bizhub
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} C0211 :Bypass Lifting Motor Failure
Nov 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Stuck on warming up. the screen will not allow any touches
The black Image unit might of failed. Was there a error code like C0211? There also could be loose connections on the PWB-M which is a control board in the upper left side in back of the machine
Sep 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Error code C-0211 Konica Minolta Bizhub C-351
It's called "Manual Bypass paper lifting failure". The manual says to check Tray 2 vertical transport motor. Check the wires to see if the are okay. Pull out tray 2, remove back cover, remove wire assembly from 4 wire saddles, remove 2 screws and the motor assembly. The should be 2 motors on the assembly and the one u need to look at is the bottom one. hope this helps.
May 22, 2009 | Konica Minolta bizhub C351 All-In-One...
Canon iR c3220 problem code E00000 0211 HELP!
problem w/fuser unit.
either it's not turning on or the temperature is not correct.
check thermistor, thermofuse, lamp
Oct 09, 2008 | Canon imageRUNNER C3220 Color Copier
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
