Question about Royal Satellite 40 Typewriter
Royal TQ 840
Typewriter only prints to the memory screen. Does not work with regulat typing strokes. How do I get it out of this mode? Thank you
  • 186 Answers
There should be either a switch or a coded feature that is set to "delay" print usually you have to hold the code key down then press the key button (probably one of the number keys)under the feature that says delay.
Posted on Sep 07, 2007
SOURCE:
Royal 501 electronic typewriter repair
iF IT HAS A LANG (LANGUAGE KEY) try it in another lang
Oct 18, 2016 | Royal Office Equipment & Supplies
I've hit a wrong key and now it won't print what I am typing it just moves along the line
Just hit the mode key until TYPE, on the display, is highlighted. There are 3 modes, TYPE (where the machine functions like a normal typewriter), L/L (Where what you are typing shows up in the display and then prints when you hit the "RETURN" button. You can make corrections, in this mode, before you print the line, which saves using your correction tape.) and STORE (which is used to store memory information, such as format and phrases.)
Sep 28, 2015 | Brother EM-430 Typewriter
How do I download brother SX-4000 electric typewriter?
If you are asking how to download to a computer file or a storage device, there is not a way without a major modification to your hardware (commonly known as a HACK to the device). Brother did not include a way to download from memory to a computer file.On the other hand, if you want to print what you have on the LCD screen you are typing in display mode. There are 2 typed of display modes (Line by line, and Auto) The way to print in display mode is;
  1. Press return if you are in Line by line.
  2. Type a complete page with and the machine will add the return when you reach the Right Margin.radarron_1.jpg
To determine what mode you are in, on the right side of the display you will see the operate section (see attached diagram) . If the triangle is pointing up you are in "Auto Return", if it is pointing down you are in "Line by Line" mode. If you don't see a triangle it should type as a normal typewriter (each letter as soon as you type it). To toggle through the modes hold the ALT key and press the OPERATE key. The keys that are activated by the ALT are color coded (same color as the ALT key) and are across the top of the keyboard.
Feb 15, 2011 | Brother SX-4000 Typewriter
Need to be able to get typewriter out of auto mode to manual mode. It prints what you type after you press the enter key, but need to complete a form - need to type as I press the key to ensure the...
Look for a delay print mode - probably a slide switch. If not, check out to see if there is a code or control button. Usually works by holding the code button in conjunction with another key. ie: Code and "D". Model # would be a help.
Oct 09, 2009 | Royal Office Equipment & Supplies
How do I get the typewriter to print as I type instead of using memory
On the right side of the keyboard is a print mode key press it and the dl print will on the display will go out and you will be OK.
DickyO
Sep 29, 2009 | IBM Wheelwriter 30 Typewriter
TA Royal 503 typewriter with a print wheel that is not aligned
Hi - there a many reasons why this happens. Try these first. Replace the ribbon. This might have become tight (faulty) and make this happen. Next clean the main rod that the carriage goes back and forth on, it sometimes get very sticky. Then place a couple of drips of oil on. This should work wonders? Best John ex OEM trained mechanic
Jul 09, 2009 | Royal Office Equipment & Supplies
Display arrow pointing to "NP"; Typewriter won't type on paper.
NP means normal print.  to change the print mode hit the MODE button
Jan 13, 2009 | Nakajima AE-740 Typewriter
Adler royal satellite 40 ribbon drive problem
Try holding the code key down and pressing the (.) period key. It is probably in the mullti strike ribbon mode.
Oct 18, 2007 | Royal Satellite 40 Typewriter
Royal Satellite 40 Typewriter Logo
129 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
