Question about Canon iR1600-2000 PS
E0012 ir 5000 - Canon iR1600-2000 PS
I need photo coppier "
I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Hope that helps!
Jul 27, 2011 | Canon imageRUNNER 5000 Copier
E0012-001
i know this is in english but the e012 code is the Drum/ITB drive motor has locked up and has stopped turning and needs to be checked and or replaced.
Jun 02, 2010 | Canon imageRUNNER C6800 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
ImageRUNNER 5000 Copier: how to set a password for ir 5000...
under User mode ( round button with * ), choose ID management. The rest is yust the reading from panel.
Pls. rate
May 05, 2010 | Canon imageRUNNER 5000 Copier
The IR 5000 does not have a port to connect to the LAN
You will need to add Print Option to the machine first, then upgrade to network firmware on the hard drive of the copier.
Jul 16, 2009 | Canon imageRUNNER 5000 Copier
Ir5000
sst itu Service Support Tool kl sm apa ya? kalo mau sst nih linkya
http://techchatter.servehttp.com/yabbse/index.php?topic=356.0
n nih frmware ir 5000-6000
http://rs147.rapidshare.com/files/197499533/__304_R5000-6000.rar
Feb 01, 2009 | Canon imageRUNNER 5000 Copier
Hello can you really help me solve the error code that i getting on my IR 5000 the code is E000012-0000
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
Dec 25, 2008 | Canon imageRUNNER 5000 Copier
Ir 5000
saya bisa bantu, tapi lokasi kerja mas dimana????
Dec 12, 2008 | Canon imageRUNNER 5000 Copier
Computers & Internet Logo
41 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
