Question about Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11 ()
The heater elements have burnt
When the heater is switched ON, the red light indication comes ON, but, the water isn't getting heated. Then i disconnected the electrodes and found that there is no continuity between the electrode terminals which indicates that the electrodes are faulty. I removed the electrodes and found that there are some holes present on it (i.e. bursted). I replaced them with the new electrodes but after 5 months the same problem re-occurred. Again the heater elements bursted. Need to find a permanent solution to this.
    Champion:
  • 305 Answers
Check your bloody water chemistry
Posted on Feb 13, 2014
  • 22 Answers
SOURCE: I have a Hayward 11 KW spa heater that was not
check the power to the relay and pressure switch just remember the problem lies where the power dies.
Posted on Feb 18, 2009
  • 139 Answers
SOURCE: Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: I can't get the pilot to light gas is present can I light it
hayward millivolt htrs are very difficult to light manually.i'm assuming your piezo ignitor is mal-functioning.use a grill lighter withn a goose neck and follow aluminu pilot tube to pilot hood
  • 12 Answers
SOURCE: hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Posted on Jun 25, 2009
  • 3 Answers
SOURCE: h100id induced pool heater runs for 4 minutes then stops heating
I just solved this about an hour ago. It's the connection from the circuit board to the ignitor. The same thing happened to me that it ran a long time and then it wouldn't. At some point it loses spark. The large wire from the board to thee= ignitor is the culprit. Take the ignitor out and press the two electrodes to about 1/4"-3/8max. Clean the surface plate where it meets the heater and also clean the brass piece on the othe end. Then clean the brass piece on the circuit board. Slide the 2 boots down a little and expose the receptacles. Press them a little with pliers, put them on their respective connections and then slide the boots back on. It started right up and has been running since! This after I bought a new gas valve $178! Let me know if this does it for you.
Posted on Aug 08, 2009
Hot water heater will not turn on
You need to have the unit checked. Two possibilities come to mind if it is an electric water heater. 1. Burnt out heating element. 2. Failed thermostatic element switch located in the unit. Many water heaters have two elements.
Jan 15, 2015 | Water Water Heaters
make sure water chemistry is correct sounds like its eating into coating of metal and shorting out or check voltage if too low will cause to overheat wires
Jul 30, 2013 | Hayward 11kw Electric Spa Hot Tub Heater...
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
I was called out because a tennants water heater wasnt working. I tried to restart the pilot. but nothing happened. I checked the gas line and it was getting gas. I checked the electronic starter and it...
if the heating element is out, the pilot will try and start , but if the thermocouple in the unit itself isn't letting the gas release,, it isn't going to fire up , Check the thermocouple , if its built into the controller valve,, your either going to have to replace that ( if its possible on that unit,, ) or get a new water heater
May 08, 2011 | General Electric Water Heaters
The unit is no longer heating the water. The red light comes on indicating that the unit is heating the water, but only cold water comes out of the faucet. We've tried raising and lowering the...
This will be a thermostat or element problem. The red light tells us that you have power to the unit. If you are handy you can test the thermostat and the element with a continuity tester. A voltmeter may also be used. This will tell you where the fault lies.
Mar 06, 2011 | Stiebel Eltron Tempra 24 Electric Hot...
The heating elements and both thermostats have been replaced, they are getting juice but the water is still cold.
when you replaced them did you bleed all of air off tank before restoring power to w/h if not you could have burnt the new ones , are you getting 220 volts at top of w/h and ck wiring again to be sure properly wired top comes first and when has reached set point of top t-stat it transfers power to bottom just like a 3-way light switch operates 120 volts always on bottom waiting on the other side of the line to heat the element on 220
Jan 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Hayward 11kw Electric Spa Hot Tub Heater Cspaxi11 () Logo
172 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
