Question about Kodak EasyShare V530 Digital Camera
Kodak easyshare v530 error l82
When I switch on the camera 3rd led is blinking red and camera's lens is in zoom position its not going in when I press shutter button and on/off button for few second its showing error L82 how to solve this problem
SOURCE: kodak easyshare z1275 not working =(
PROBLEM - Camera will not turn on at all regardless of battery used. Happened after about 8 months of use. Kodak instructed me to send the camera in of warranty repair. MCU was replaced. The unfortunate thing is that I have the same problem again, 7 months later and I am guessing it is not a warranty repair this time.
Posted on Feb 24, 2009
sandipmistry
  • 56 Answers
SOURCE: lens problems
there is a problem wit your lens section, get it repaired with your company professionals. Your camera may be fallen or being pressed from front side by someone. The new ZOOM will give the same best result and no further problems.
Posted on Apr 24, 2009
  • 68 Answers
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Posted on Oct 16, 2009
  • 11967 Answers
SOURCE: kodak easyshare c182 lens error 111
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 13, 2010
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
Lens stuck on zoom, and rattle
sure your machine has been exposed to sand and moisture, so this all stuck and short circuit, take it to a technician but I would advise discard
Aug 04, 2012 | Kodak EASYSHARE M340 Digital Camera
I have the Kodak EasyShare V530 and every time i turn it on it gives me a message that says "camera error #E45 see user's guide" then it turns off. Unfortunately i dont have my user's guide. Is...
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=21cc7420d5ae338b61a176f16d1146f3&modelid=200385&q=Kodak+V530
Here is the link to download your manual.
The error code indicates that there is a stuck lens issue.
Check to see if any foriegn matter...i.e. dirt, has gotten into where the zoom lens opens out at. That is more than likely the point that is causing this error.
Jan 18, 2011 | Cameras
Zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Kodak V530 won't upload pictures from docking station to comuter.
If your camera have a sd/mmc card just buy a sd card reader and plug it in your pc. it will transfer all your pictures to your computer.
user guide for your camera
http://support.en.kodak.com/app/answers/detail/a_id/18624/~/kodak-easyshare-v530-zoom-digital-camera%C2%A0%E2%80%94%C2%A0users-guide/selected/true
Jun 10, 2017 | Kodak EasyShare V530 Digital Camera
My kodak
Check batteries and try again please .......
Oct 16, 2008 | Kodak EasyShare V530 Digital Camera
Kodak easyshare V530 camera turns on then straight back off again bought a new battery but still does the same. Lens goes out a bit but then straight back again.
Feb 20, 2008 | Kodak EasyShare V530 Digital Camera
My kodek v530 camera wont start
My camera has the same problem. How could Kodak get away with that? Kodak V530 is a piece of garbage. I called Kodak's customer service. They offered repair for only $110. It is ridiculous, why we have to pay for manufactured defect? Take a look at the Kodak V530 on eBay. There are a lot of defective V530 up for sale. The government should review this E45 error lens issue, and have them take care of that. Or we should never buy Kodak again!!!!
Dec 22, 2007 | Kodak EasyShare V530 Digital Camera
Video and sound out of sync
Dec 02, 2007 | Kodak EasyShare V530 Digital Camera
Zoom does not work
Apr 16, 2007 | Kodak EasyShare V530 Digital Camera
E 45 error
Feb 23, 2007 | Kodak EasyShare V530 Digital Camera
Kodak EasyShare V530 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
