Question about Lenovo 3000 Computers & Internet
G400 laptop My laptop does not display, there are power supply but the screen does not on itself.,. Can you help...
  • sam hkp Aug 01, 2013
    Yes There are power supply to the CPU but no sign of any power connection on the screen... I have just keep it like that..
    New Friend:
  • 10 Answers
Do you mean the PC powers up, but the screen doesn't show?
Posted on Jul 30, 2013
My laptop Lenovo g400.when I turn on my laptop its functioning but after 3 hours or less iturn off my laptop but when I I turn on again there is no screen display its all black but the power led is and...
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
If it doesn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Oct 09, 2013 | Lenovo 3000 Computers & Internet
Display flickering
It could be a loose connection from the LCD screen to the motherboard. However, this can be risky to fix unless you are experienced with laptop repair.
It could also be faulty graphics card.
Graphics drivers may need updating.
The screen itself could be faulty and failing.
The system power supply may be faulty and not providing enough power.
Basically, it needs service - probably by a certified Dell technician.
Oct 21, 2012 | Dell Inspiron 4100 Laptop AC Power Adapter...
Lenovo G400 cannot power up after few times and now completely dead?
Try a backup power adapter/cable. The Power supply may have died.
Jun 11, 2011 | Lenovo ThinkPad G40 PC Notebook
Zg5 has blank screen even though power light is on. Computer was working fine and after turning it off if refuses to display anything but blank screen. Battery was removed for a short while then replaced...
Welcome to FixYa!
It seems that you are having problem with the LCD or the display on the laptop, you just said that its tyrning on but there is no display appearing on the screen. This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this information will help. Thank you for using FixYa!
May 17, 2011 | Acer Aspire One PC Notebook
SCREEN WENT BLANK ON MY HP PAVILION LAPTOP. REBOOTED AT LAPTOP BOOTS UP FINE, BUT STILL HAS BLANK SCREEN. AUDIO WORKS, AND CAP LOCK AND NUM LOCK FLASH. dtcorman@comcast.net
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens,there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 21, 2011 | Computers & Internet
My lenovo 3000 G410 when ia tr to start it nothing happens???? help
Is there power when you turn the system On?
In your case it is very difficult to find out which is causing the system not to power, this can be multiple devices on your ssytem.
trying to eliminate one device after another try following the steps below:
>remove the Battery from the system, unhook the adaptor as well then Press and Hold down the power button for 7-10 seconds to drain any power on your motherboard.
>after power draining the system connect the adaptor to your laptop, do not insert the battery yet, Power the system without the battery, if the system turns on leave it turned on for about a minute then shut it down normally.
>insert the battery to the laptop turn the system on if this turns on without any error then your concern is probably ok and fixed.
>but if the system still does not power up having the battery connected to the machine a device on your system can or maybe damaged either the Battery or the Motherboard having an issue with the battery conencted to the machine...
if your system is in warranty call Lenovo and have it sent to teh service center for proper checking and repairs.
Jun 29, 2010 | Lenovo 3000 Y410 Laptop
My monitor does not work
Turn the screen of the laptop to catch some light from the window or a lamp
Can you see the Window screen very faintly in the background, if you can the backlight or the inverter has gone
If yoyu cant it is screen itself
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Getting the date on the photo
camera mode date time display on it or in some camera it only shows
Jun 18, 2009 | Konica Minolta DiMAGE G400 Digital Camera
Cannot tune to local stations
- The 0.2MHz odd steps are standard for US radios. Try resetting the radio (recessed button under the front panel) If this a US radio then this may not help. If you have lost the manual then go here:- http://books.jvcservice.com/booklist.asp?Model=KD-G400 Come back and say if this helped or not, I could dig a bit deeper.. -
Oct 04, 2007 | JVC Sirius KD-G400 CD Player
Computers & Internet Logo
70 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
