Question about Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black
My kurzweil pro 3i digital piano takes time to start, some times souds like clicking
When i turn it on sound doesnt come and on display write loading which some times never finished ! most of the times starts to produce a sound like klicking and doesnt stop ! i neeed to turn it off
4 Suggested Answers
  • 5603 Answers
SOURCE: I have a Kurzweil Mark-Pro
I don't know what you "tested" the power supply board with, but I would use an oscilloscope to look at the outputs to see if any of the regulators are drooping. Clicking is a broad term... if it is a relay, it PROBABLY is for speaker protection and senses balance of the power amps.
With a two minute delay, this is PROBABLY a thermal issue... Use freeze mist/circuit cooler to find suspicious parts.
Posted on Jan 02, 2011
  • 1212 Answers
SOURCE: Kurzweil Sp2x
It may be the line current at those venues.
If you have a lightweight switchmode supply, you can try adding some ferrites to the power cord from the wall. but you almost need to switch to an older style heavy transformer supply for reliablity. It is my guess there is a great deal of noise on the supply current at those vehues you have had problems at. That noise does not play well with switchmode.
Posted on Feb 05, 2012
  • 1212 Answers
SOURCE: kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Posted on Sep 25, 2012
How old is my Packard piano serial number 130213
Your piano was manufactured sometime between 1925 - 1930. As far as I can discern, it cannot be pinned down any more specifically than that, nor can it be determined where it was constructed. Sorry. . .
May 04, 2016 | Kurzweil Music Systems Kurzweil MarkPro...
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
May 18, 2014 | Kurzweil Music Systems Kurzweil SP3X...
Kurzweil Sp2x
Feb 04, 2012 | Kurzweil Music
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
Hello, My KURZWEIL start but it only blinking a rectangel on display to the left. There is no other lights, all other is dead Morten Lauritz
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
Sep 15, 2011 | Kurzweil SP3X 88-Key Stage Piano
I have a Kurzweil Mark-Pro TWOi. It takes several minutes to turn on, and keeps resetting and clicking while booting up. My guess is a bad capacitor somewhere. I looked at the power board, and it looks...
Jan 01, 2011 | Kurzweil SP4-7 76 Note Digital Stage...
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Sep 02, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Open Questions:
See all Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Questions
Kurzweil SP4-7 76 Note Digital Stage Piano, Semi Weighted Keys, 128 Programs, 64 Split Polyphony, Split Layer, Setup Mode, 24 Bit DSP Technology, Black Logo
26 people viewed this question
Top Kurzweil Music Experts
drivealot
john cordey
john cordey
rhodesworks
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
