Question about Samsung DVD-V1000 DVD Player/VCR
DVD V1000 samsung
Where can i get a fuse for DVD V1000 samsung 1.6a 250v .51 NM
Re: DVD V1000 samsung - Samsung DVD-V1000 DVD Player/VCR DVD & Blu-Ray Players
Posted on Sep 01, 2007
0 characters
3 Points
Fuse blows after replacement when I plug it in
Hi,you need to check the bridge rectifier for short circuit.
Oct 13, 2013 | Samsung DVD-V1000 DVD Player/VCR
Blows fuses
Hi,u need to have the powersupply replaced .
Can I copy vhs to dvd with my samsung DVD V1000?
only if the dvd is a dvd burner can you copy it to dvd from vhs if it isint go to walmart or best buy and get a dvd burner and hook it to you combe then you can record vhs or dvd to the dvd burner
Jan 12, 2011 | Samsung DVD-V1000 DVD Player/VCR
How to install samsung dvd-v1000 dvd/vcr combo ? I lost instructions and need to know what cords to hook up where ?
if your using rca cables then plug the coresponding colors from the out on the dvd to the input on the tv
Dec 21, 2010 | Samsung DVD-V1000 DVD Player/VCR
Plugged in but no power
Try replacing the fuse inside the unit. remove the two side screws and the three rear screws. Fuse is located near the power supply cord.
Feb 15, 2010 | Samsung DVD-V1000 DVD Player/VCR
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Feb 19, 2009 | Samsung DVD-V1000 DVD Player/VCR
No power
What the major problem of your power supply suspect ?
you can check from the end to front or from the front to the end...he..he....he...
Mar 14, 2008 | Samsung DVD-V1000 DVD Player/VCR
Samsung DVD-V1000
Feb 09, 2008 | Samsung DVD-V1000 DVD Player/VCR
Will not play CD-Rs
DVD players will play CD's and MUSIC CD-R's. Some will play MP3's IF the unit is so designed. You would see the 'MP3' logo on the front.
Aug 20, 2006 | Samsung DVD-V1000 DVD Player/VCR
Samsung DVD-V1000 DVD Player/VCR Logo
195 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
