Tascam din unlock - Audio Players & Recorders
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
Getting error message "Din Unlock
That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
May 03, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
Din unlock c-17 on sony mini disc
If “Din Unlock” flashes in the display
• The digital program source is not connected as you set
with INPUT
To continue, connect the program source properly.
• The program source is not on.
Turn on the program source.
May 11, 2010 | Sony MDS-JB940 Mini Disc Player
Need cords
8-pin mini din cables p/n: 9109030600, you can buy them from any authorized TASCAM/TEAC dealer.
Jan 11, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
What cables for yamaha keyboard psr295 to connect with tascam 144
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Aug 01, 2008 | Tascam US-144 Sound Card
119 people viewed this question
 Grubhead
Grubhead
