Question about Electric Demolition Jackhammer
Chicago electric 2005-2007 model
It has orange& gray case. The motor slowed down and started smoking. I check the brushs,they are 3/4in.long. I clean motor with electric motor clearner, made no differants.
3 Suggested Answers
  • 1456 Answers
SOURCE: I have an Atco Regent
Hello
The generator makes the particular rotary cutting blades spin so that you can cut turf. Sometimes the particular cut grass penetrates the generator shaft and will either temperature it up to standstill or perhaps clog the particular motor. The motor needs to be checked for almost any foreign things, the armature needs to be rotated to find out if that moves openly.
A smoking rectifier is not good, it will need to be replaced.
The rectifier is required to switch AC (wall power) to unregulated DC.The brushes are the power input to the motor, with the slowing,the brushes are shorted to provide a dynamic break which quickly stops the blades. You will need to test the motor to see if that caused the rectifier to go.
I am not sure what the specs would be for resistance but it should be in the 10 ohm range for a 12 amp motor (120 volts/12 amps=10 ohms)
Posted on Apr 26, 2011
  • 640 Answers
SOURCE: My craftsman 12 amp 18"
If the brushes are really short, that could be a lot of the loss of power if they are not making good contact with the commutator. If you can not find your model number, see if you can locate an identical one or one of the same motor. You may have to try going into Sears to see if there is one on the sales floor and get the model number off that one.
Posted on Aug 24, 2011
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Blower does not turn on
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 03, 2014 | Toro Garden
Snow blower shorted out
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Motor was losing power and burning
Jan 13, 2014 | Toro "Toro" Super Blower/Vac
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Electric Demolition Jackhammer Logo
63 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
