Braemer HX OT2 open at start (fault 19) how to fix
Power went out now Spectrolink control showing error code 19 and needs the HXOT1 and HXOT2 switch to be replaced, how can I do this before I reset controller
SOURCE: Error code F153
Did anyone ever find out the solution to this issues. I have the same f153 fault code and want to know how to solve this
RLA
Posted on Oct 18, 2008
alicantecoli
  • 22326 Answers
SOURCE: reset fault code on 1996 jaguar x300
dealer only sorry
Posted on Dec 10, 2008
odiegh
  • 81 Answers
SOURCE: Canon Gp200 Error Code E000-001
I looked up the e000 and it said it's for the fuser using not heating up and 001 error code and it is that the fuser unit is overheating. So seem to me you have a bad fuser unit.
Posted on Jan 02, 2009
  • 9 Answers
SOURCE: Whirlpool Duet Front loader mdl WFW8300SW00 will not start
I had a variety of error codes show up on my duet, and I'm not sure but I seem to recall a 31, but the most constant was 02. I took off the front cover, pulled the white plug out from the unit, put a bucket under it, unscrewed it and drained it. It may be the MCU is having problems because the washer got plugged up.
Posted on Apr 24, 2009
relaga58
  • 158 Answers
SOURCE: I have Carrier mod#24ANA760A300 Infinity system.
no unless there is a loose connection of the wires or terminals between switch and controller
Posted on Jul 22, 2009
MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
Remove the wall plug which _should_ reset the main board. If that doesn't work, you have to manually drain it by unclipping the drain hose and lowering it into a bucket.
Error 12 (E12)
Washing machine has detected an overfill situation This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
  • Check for overfoaming or over soaping
  • Check the air chamber and the pressure switch hose
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3848-logik-washing-machine-error-codes
Jan 20, 2016 | Washing Machines
Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Oct 03, 2013 | Washing Machines
Braeme HX OT2 open at start (fault 19) how to fix
says I should change the HX OT1 and HX OT2 switches and reset in service mode, however can't find where to get these
Jul 30, 2013 | Heating & Cooling
How to fix error code 19 on honda civic dx 1993 5 speed
Error code 19 on a Honda civic refers to AT lock up system malfunction causes ---Lock up control system. Have the code item repaired first and the second fault may be fixed also.
Apr 20, 2013 | Honda Cars & Trucks
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Braemer Spectrolink ducted heating - heat won't turn on
MY GAS FURINACE IS LOCKOUT WHAT IS SOLUTION
Mar 23, 2010 | Heating & Cooling
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
Mar 16, 2007 | GE DBVH512EFWW Dryer
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
