Bramer TG error 19 HX OT2 open at start
Spectrolink showing code 19 and needs to be reset how do we change HXOT1 and HXOT2 switches to do so
3 Suggested Answers
  • 173 Answers
SOURCE: YAMAHA R1 07 BIKE
Try disconnecting the battery for a few minutes, then reconnect. See if this clears the trouble and code.
Posted on Feb 03, 2011
  • 5 Answers
SOURCE: Spectrolink heater won't start
Thermister was not installed correctly 3 meters from heater
Posted on Apr 28, 2011
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
Braeme HX OT2 open at start (fault 19) how to fix
says I should change the HX OT1 and HX OT2 switches and reset in service mode, however can't find where to get these
Jul 30, 2013 | Heating & Cooling
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
My new gaggia accademia won't work. It shows error code 19. Can you help me?
Hi, Error 19 is not known by me. Sounds like something is not resetting or has failed. Try turning off the machine at the main power switch and unplug it from the wall for a few minuites. Remove the dreggs draw and drain tray and replace them before you plug it back in. This will allow the machine to reset. Dazza REPAIRER
Sep 24, 2011 | Gaggia Coffee Makers & Espresso Machines
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
The Technician or the F***ing Person who cleaned your ducts messed up the Sensor that verifies the temperature
Apr 21, 2010 | Honeywell Programmable Thermostat Heater
95 Chevy 6.5 lt turbo diesel Error Code 19 . Truck is hard starting and sounds louder. The code reader said code 19 crankshaft sensor.
YEP CODE 19 IS CRANKSHAFT POSITION REFERENCE ERROR.CKP SENSOR SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND.
Sep 17, 2009 | 1995 Chevrolet Silverado 2500
My bmw z3 service engine light is on and the codes show P1899 and P1898. can you help
Error codes not in service manual. presumme dealers can assist you with a pnhonecall for error codes.
BMW SERVICE RESET
Take a small wire, paperclip, or elect wire and bend like a horseshoe. No light or equipment necessary Open the diagnostic data port, the one were the little pacman centre is located. Turn the ignition to position 2, don’t start. Connect pin7 always first and then pin 19. Hold for 4 seconds. Remove wire and settings will be reset. Warning if you hold the wire longer than 10 seconds you may reset inspection intervals 1 and 2.
I’ve done this twice and it definitely work on my E36
Aug 12, 2009 | 1998 BMW Z3 Roadster
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
