Megmeet ccfl blinking no picture modle mip320fl-1
L1900e dark backlight
1st try to check circuit that is operating CCFL, otherwise replace CCFL , it does not look like ccfl problem
Apr 12, 2014 | Samsung Computers & Internet
Picture keeps going of sound stays on.i have switch of and on to get picture back
Hello, i have some method you may try.
1. Turn on your TV set, than wait whail untill picture off.
2. After picture off, try to knocking TFT panel smoothly. If you see flashing light from panel, its mean the backlight panel switched off.
Backlight panel consist of inverter board and ccfl inside the panel. If one of ccfl's burn out, all ccfl's will switched off by inverter board. make sure that the problem comes from one of these part.
Replace it.
I hope that will solve your problem.
Thanks.
Mar 10, 2011 | Samsung Televison & Video
Tv shuts off when you turn it on again it will play a minute
I think this might be bad/swollen capacitors in your power supply, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the PS secondary circuit (may cause the red light blink or shutdown problems).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
OK for the Megmeet MLT169A with red flashing LED when turned on we found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Sep 09, 2009 | Akai LCT3201TD 32 in. LCD Television
Can,t get it to turn on.
Does the red light come on? does it go green but no picture? Here are few possible solutions:
1) Swollen caps on the secondary circuit.
Sep 05, 2009 | Akai LCT3201TD 32 in. LCD Television
T.v. won't turn on
The following parts can be purchased at digikey.com or mouser.com web site. I am also posting all of the things I have found so far with these TVs.
1) Swollen caps on the secondary circuit (may cause the red light blink problem, but also see below).
OK for the Megmeet MLT169A with red flashing LED when turned on I found that IC7 was bad. This is an SMT component on the solder side of the power supply. It is a 4407P (P channel 30V MOSFET). For testing purposes, we jumped across it to feed +5V to the TV permenently instead of allowing +5V to go into standby.
Aug 19, 2009 | Akai LCT3785TA 37 in. LCD HDTV
TV won't turn onthe red light just blinks when I push the power button.
I think this might be bad/swollen capacitors, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
1) Swollen caps on the secondary circuit (may cause the red light blink problem).
Aug 10, 2009 | Akai LCT3201TD 32 in. LCD Television
My laptop blinks several times ,want to have fix the problem
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 09, 2009 | Lenovo ThinkPad X200 Notebook
Toshiba satellite a135 monitor goes black
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S2386 Notebook
Hp laptop screen blinks during use
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 12, 2009 | HP Pavilion dv6000z Notebook
RCA TV GEMSTAR GUIDE PLUS GOLD
what is this TV's modle #?
Aug 24, 2008 | RCA F32650 32" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
