Question about Garbage Disposals
Kenmore 400 garbage disposal
Seems a center gasket came out and plates rattle when trying to run disposal
  • 5,089 Answers
2 Suggested Answers
  • 202 Answers
SOURCE: Garbage disposal runs but will not take garbage down
can you turn it on for me? I would like to see and hear whats going on to better help diagnose, more than likely the "blade" that spins has detached from the disposal motor assembly or the "blade" my be caught/stuck in place, to resolve this issue.
Unplug the disposal(should be plugged in under the sink)Grab a bucket to place under sink to catch waterremove the sink pipe assembly+disposal (remove the disposal)the water should drain into the bucket from the sink.remove and clean the disposal trap, looking for obstructions while you do so.after cleaning and searching for obstruction, reassemble the unit as it was making sure to reinstall all washers, guards and bolts, after you reassemble the unit plug it back in and test it, if you get the same results then there may be a strong possibility the unit suffers from a defect or damage in which case you may need to replace the whole unit or just part it all depends... good luck... more question just ask
Posted on Mar 29, 2013
Slow drain on garbage disposals side of sink
Try running ice cubes through it, it will make a lot of noise but that should clean it out. Please slowly run the cold water with the ice.
I do not like chemicals if they can be avoided. d
Nov 27, 2014 | Kenmore 1/3 hp Food Waste Disposer
How to remove plastic cover from Kenmore disposer model 17567540
Usually, disposals are not a repairable item.
The loose shredder plate is integral with the motor shaft so they cannot come loose unless the disposal needs replacement.
Following link has part resources, manuals, and installation tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Kenmore is serviced by Sears, and you can order parts from Sears, and view some parts sheets online at their site.
Gene
Water Heater Timers Save Money
Aug 02, 2014 | Garbage Disposals
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
Add a comment and say where you are getting the parts and which model
May 25, 2013 | Kenmore 3/4 hp Food Waste Disposer
Garbage Disposals Logo
244 people viewed this question
Top Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Garbage Disposal Expert? Answer questions, earn points and help others
