Temperature control panel doesnt work and water /ice despeser
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: the door panel on a adora ge fridge doesnt work it is only a year
You may have lost a thermal fuse.
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
SOURCE: GE Fridge #GSS25LGMBWW water and ice control panel not working
Your dispensor board , has lost communication to the main control board . You will need to replace the board , which is located behind the refrig , behind the 8 " X 10 " , small panel . The pt # is WR55X10942 . You do NOT need to replace the board on the dispensor . The board behind the refrig , is , easily replaceable .
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
