Question about Amana NED7200TW Electric Dryer
Error codes ts on Amana will not reset error code after replacing thermistor. Does appear that the chime button is working when trying to access the codes
4 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Jul 30, 2011
Daniel S
  • 4323 Answers
SOURCE: I have an amana gas
Hi
TS/T5 error means that the dryer thermister is either shorted or open. If you have already cleaned the lint filter then it is the thermister that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this part for continuity and if bad replace it, as it cannot be reset. If thermister is fine then test the thermostat, thermal fuse located near thermister for continuity. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 31, 2011
  • 3 Answers
SOURCE: TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Posted on Aug 24, 2012
What is error code ts
Thermistor is bad. Call the Company, they should send you a new one. 1-800-555-1212, toll free directory for Company phone numbers.
Aug 27, 2014 | Amana NGD7200TW Gas Dryer
Tip
Samsung dryer error codes
Samsung Dryer Fault Codes
ts Thermistor shortCheck for restricted vent. Replace thermistortoThermistor openCheck for restricted vent Replace Thermistor
do Door OpenCheck connections. Replace door switch.
FE Power Source Frequency errorCheck power source
dF Door circuit failureCheck wiring to door switch. Replace door switch
hE Heater errorRestricted vent. Replace thermistor.
bE Button ErrorCheck and / or replace PCB
od Over drySensor Bar open. Adjust time up excessively.
Et eeprom failureReplace Eeprom
on Apr 14, 2015 | Dryers
T5 error code
test the thermostat and thermistor too and replace, if the problem persist, clean the ducts, or need to replace the control board if the problem . If the problem continue
make this test.
5. Power ON
Oct 01, 2013 | Amana NED7200TW Electric Dryer
NED7200tw t5 error Code
5. Power ON
Aug 08, 2012 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
How do i clear the code " ts" after replacing thermister Thank you
The error "tS" actually means the thermistor is shorted. It flashes when the thermistor is indeed shorted, the thermistor wires are shorted, or the timer/control is faulty. There's no necessity to reset the machine. The problem here is not the thermistor but a shorted wire or a faulty timer/control. One simple way to find out is by disconnecting the thermistor and insulating the wire terminals then starting the dryer. If the error code does not vanish, then it is proven with moral certainty that there is a wire short circuit or a timer/control problem. Check and make sure that there's no such wire short circuit or no part of which is touching the dryer cabinet then if the error is still there, disconnect the wire harness from the the timer control. The timer/control is indeed faulty if the error code persists even after the wire harness is disconnected therefrom.
You have a faulty thermistor if the error code vanishes after the thermistor is disconnected. Normal thermistor resistance is around 10000 ohms at room temperature.
Aug 12, 2011 | Amana NED7200TW Electric Dryer
Code looks like an upside down F with either a 5 or s. Push the start button and code keeps showing. all the other functions of the control panel seem to be working.
The upside looking F is really a lower case T and the 5 is an S. The code ts is related to the Thermistor which is on the outside of the blower housing. The part runs about $30
Jun 22, 2011 | Amana NED7200TW Electric Dryer
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Maytag neptune MDE9700AYW ts t5 error
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
Amana NED7200TW Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
