Hp mouse suite 2.3 - Computers & Internet
My mouse scroller is not working
The above symptom is associated with, but not limited to, the following systems:
  • ThinkCentre M70e, M70z, M71e, M76, M77, M80, M81, M90, M90p, M90z, M91, M91p, Edge 71z, Edge 91z
Applies to:
  • Microsoft Windows 7 in XP Mode
The system is configured with the following:
Windows XP Mode in Windows Virtual PC on a computer that is running Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Lenovo USB mouse driver for Windows 7 (Lenovo Mouse Suite)
Additional Information:
As of writing this tip, Lenovo Mouse Suite Version 6.48 can be downloaded.
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS014888
Lenovo USB mouse driver for Windows 7 (32-bit and 64-bit), Vista (32-bit and 64-bit), and XP.Uninstall Lenovo Mouse Suite.
  1. Click Start, then click Control Panel, View By: Category.
  2. Under Programs, click Uninstall a program.
  3. Right-click Lenovo Mouse Suite, then click Uninstall/Change. You may see a dialog stating, "Windows needs your permission to continue." If you see this dialog, click Continue.
  4. Follow the instruction on the screen to complete the uninstall process.
Other steps.
If you still need some Lenovo Mouse Suite function under Windows 7, the following steps may effective.
  1. Mouse Properties
  2. Select "Lenovo" Tab > Advanced Properties.
  3. Select "Wheel" Tab
  4. Change Wheel setting to "Use Microsoft Office 97 Scrolling Emulation Only" from "Enable Universal Scrolling."
Feb 26, 2013 | Lenovo Computers & Internet
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
Mar 12, 2017 | HP Wireless Optical Mouse
My Dynex wireless mouse doesn't work? am I supposed to install any drivers? Im using Hp laptop dv4-1435dx with vista home premium
There is a Dynex software suite that comes on a disk with the mouse -- this suite provides the mouse's driver as well as additional functionality such as changing button properties. You can download the driver from DynexProducts.com (be sure to get the right one for your specific mouse and operating system).
Nov 11, 2010 | Dynex Wireless Optical Mouse
My HP Optical mouse Left Mouse Button has stopped working. The RMB still performs its function (so batteries on mouse still OK etc). I have tried shfitng the USB port etc but nothing seems to fix the...
Similar problem which I resolved today.
I have a hp wireless mouse model no. 5189URF. I bought this in hp online in April 2009. It needs 2 x AA Alkaline batteries.
Steps I did to resolve.
1. Removed battery cover.
2. Removed batteries below which 2 screws exist.
3. Remove 2 screws and remove the top casing of mouse.
4. You can see 2 very small square push button corresponding to left and right clicks in mouse.
5. try to press the left button and make sure its free. The issue seem to be that this button becomes rusty internally and lost contact. Therefore clicks are not recognized. You may need to press it repeatedly and also with a slight thrust circumferentially.
6. You can test your mouse in WIndows Help & support option linked with HP hardware diagnostics tool.
Oct 31, 2010 | HP Wireless Optical Mouse
When I tap on the touch pad on a HP Pavilion dv7 cursor jumps
Go to your control panel and double click on your mouse icon to get to your mouse properties. Go to "Pointer Options" and make sure that the "snap to" box is unchecked.
Mar 21, 2010 | HP Computers & Internet
HP pavilion desktop only has built in RJ45 connector--problem?
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
This is a very large subject so you need to decide what you want to do first!
See
http://www.computerhope.com/issues/ch000469.htm#04
or
http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
or even
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Sep 12, 2009 | HP Pavilion Media Center TV Desktop with...
I purchased a hp wireless mouse for a second hand store. I'm not sure how to install it?
it should install automatically as most are plug and play.
connect the USB with the wireless piece into USB port it should then invoke found new hardware etc. if it cannot find a driver o to the HPS site tech support area and find the software driver to suit
Jun 22, 2009 | HP P2360AA Keyboard/Mouse
HAVE HP MOUSE, PRODUCT NUMBER PP034AA CAN YOU
GO 2 HP DOWN LOAD CENTER 4 DRIVERS FAILING THAT GO 2 CONTROLL PANNAL ,DEVICE MANEGER 2 C IF ITS RECONISED
Feb 20, 2009 | HP Wireless Optical Mouse
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
