Scanners
Problem for Scanners
Generic problem for all Scanners
Samsung scx-4521f lines on feeder scan
By f_c97676 on Apr 01, 2009
Only used feeder for fax but recently discovered that faxes sent had two parallel lines aprrox 10mm apart slightly to the right hand side
Used the feeder for photo copy which ralso resulted in the lines on the output paper
Comments:
Apr 02, 2009
- Thank you
It appears that the substance on the thin scanner was a manufacturer use substance not easily seen by eye but apparent when a finger was used to touch over
Best Solution
posted on Apr 01, 2009
Very Helpful)
Xrtsteve
Rank: Master
Rating: 94%, 6 votes
Youll find that the most common problem with fax machines is that the scanner head that the paper passes over actually gets gritty and dirty. Remember it only takes a spek sitting in there.
Try a damp cloth (not to much Water) and wipe down the sensor reader, It will take a little bit of trial and error but mainly this is the common problem. also try wiping down all the wheels and rollers that the paper runs over as well. Otherwise it could be the recieval end that has a dirty paper feed wheel.
Sometimes it is also common that the internal scanner/sensor reader wears out and needs replacement.
IF this is the case its generally cheaper to buy another fax. Hopefully the above helps for you so you dont have to buy another one
Cheers
Steve
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Very Helpful)
waqar697
Rank: Wiz
Rating: 85%, 49 votes
check the scanner glass it might have some dust on top of it clean it with a soft cloth properly. it should solve your problem
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Scanners
Questions and Unsolved Problems for Scanners
Answer
I need a hendheld pen scan suitable for XP and editable on word, to save especially half of the... (More)
Answer
HP scanner 6310 won't scan. It tells me to check documents to trouble shoot. I don't have the... (More)
Answer
My check light is blinking 6 times, then pauses, then repeats. What can I do to... (More)
Answer
I have a hp scanjet 4890. I can load a driver, but I cannot load hp solution center in windows 7.... (More)
Answer
after a click on hp director i see a message CLR error 800004005 solve this
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanners Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
