Rogers remote control
To control rogers av 9000
Have an Element TV and the remote will shut the TV off and on plus do the SAT/CAB Directv I can turn on and off but the channels won't gel so I can watch The TV
Search Results
    Your remote reprogramming woes solved - Rogers RedBoard
    redboard.rogers.com/.../your-remote-reprogram...
    Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code. ... All the steps you'll need to program your Rogers Remote to control all your home theatre devices. .... the Cable turns on and off and volume etc. but will not shut offthe tv. ..... I bought a Element Electronic Smart TV and have set it up.
    Support ' Element Electronics - Elementelectronics.com
    www.elementelectronics.com/support/
    Element ElectronicsA description for this result is not available because of this site's robots.txt - learn more.
    DIRECTV - Support: Your Remote Control
    www.directv.com/DTVAPP/equipment/demoInfo.jsp?assetId...
    DirecTVTrying to get your DIRECTV remote control to work with other devices? ... TV Power On & Off - If your receiver turns off while the TV turns on, press TV Power On until they ... Power Key - Your DIRECTV™ Remote can operate alternate devices.
    [PDF]Get to know your remote control Need more help ... - AT&T
Jan 31, 2016 | RCA Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Need a remote code for fluid tv using rogers remote
Hi MiMi I attempted to search for the Code for your TV under several of the Rogers remotes and was unable to find one. You can do a general search for a code on any of them following some minor instructions. Navigate to link , choose the remote that looks like yours and then to the left will be choice to search all possible codes. Hope this helps. Good luck Rogers Cable Remote Support
Nov 04, 2014 | Televison & Video
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 02, 2014 | URC-Universal-Remote-Controls Remote...
Www urcsupport com
Use the auto code search function of the remote.
Apr 20, 2017 | Televison & Video
JVC 27" TV model do not know what are the codes
Hi Roger,
You didn't mention the brand of your universal remote control. Anyway, here are the universal code for JVC Tv.
JVC Codes: 013/ 054/ 055/ 060/ 065/ 067/ 089
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 15, 2011 | JVC AV-27230 27" TV
How would i program my rogers remote to my lg tv to be able to change the volume without having to use the two remotes
Please rate this solution if you find it helpful:
It would help to specify the model of remote control or TV, however, here is the guide to programming your Rogers remote for any television:
http://www.rogersdiscover.com/cable-tv/learn-about-your-rogers-remote-control/
Oct 14, 2010 | LG 42LC2D 42 in. LCD HDTV
Remote control code
depending on the remote you have from rogers but the newest remote has 5 device's across the top we call it a 5 button there is a 3 and a 4 and a fat 5 button that is the old pvr remote all are pretty much the same in setting up easiest way is on 5 button remotes select the device ie. tv pres and hold setup untill light flashes 3 times enter 9-9-1 the with the tv on press ch+ button untill tv turns off once tv is off press setup to lock in the code test it by pressing tv then pressing power should turn tv back on if not repeat previous steps untill you get the right code some tv models are not compatible with the rogers remote 3 and 4 button pretty much the same except insted of a setup button you have to press and hold tv and select at the same time untill light flashes 3 times press 9-9-1 then press tv button untill tv turns off press select to lock into place
Dec 29, 2007 | GRIFFIN TECHNOLOGYTotal Remote-PDA Remote...
 Grubhead
Grubhead
