Question about Garden
Black flag propane fogger
The chemical leaks from bottom
Why is there a strong gas odor?
Suggest you turn off the gas supply immediately! and check for a poor connection or other cause. Do not attempt to light the pilot again until the cause of the leak has been found and repaired!
Nov 19, 2015 | Home
Parts list for black flag fogger
Where do I buy a replacement front mesh cover??
May 22, 2013 | Fountainhead/Burgess Prod Black Flag...
Trigger is not pumping properly
The plunger needs a new leather, but question is where can you buy it. The problem is caused by the side pull on the plunger causing it to wear unevenly to one side. Could be solved in the manufacture if they would build the trigger to pull it up evenly.
Jul 10, 2011 | Fountainhead/Burgess Prod Black Flag...
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
I did not think about draining my pool heater with our recent cold weather in Houston... I just don't use the heater much. Now, I see water leaking out the bottom (underneath) when the pump is on.....
bad heat exchange either chemical damage not covered by warranty or overheating low gas pressure (tubes start bending and leaking) also not warranty need new heat exchange make sure to find out what caused it and find out how to prevent for next time
Feb 11, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
Machine seems clogged
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
Jun 27, 2009 | Fountainhead/Burgess Prod Black Flag...
Fogger does not produce fog
It is common for the nozzle to plug up. If it is brass, it will unscrew and can be cleaned with a very small drill bit.
May 31, 2009 | Fountainhead/Burgess Prod Black Flag...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
