Question about Roland Boss DR 880 Dr Rhythm Drum Machine
My dr 880 wont give any output
No output from phones jack or master out
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Is it possible to connect my Boss multiple effects ME-25 to my BR-800 recorder. If so how, and can it then be linked to an amp (again how)
Hello Alan.
Yes you can connect your ME-25 to the BR-800, there is no risk to damage any. it is simple, you may use both outputs of the pedal and send them via two normal 1/4 plug guitar cables to two of the channels of the DR (i.e. ch 1 & 2) to avoid an initial saturation of the recording preamp, set the input sens pot at minimum and the sliders very close to minimum as you try playing and looking the levels on the display and adjunting them to the optimum.
To connect the DR to an amp you should use the pair of RCA jacks named LINE OUT (R & L) depending of the amp you have there might be the need for a conversion cable or plug adapters. The out put of the DR is stereo, and if you want to use a guitar amp, commonly mono, you should mix both channels to send them to one input, this can be done by putting two 10 kohms resistors in series with each channel output and joining the other end to the input.
Good luck and best wishes
Nov 20, 2014 | Roland Boss BR-800 Digital Recorder
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Headphone volume needs increased
are you running straight off your amp with head phones? Or are you using the headphone jack as a stereo output? if just headphones. check the cord for a volume control. very common these days to have that be there. if there isn't one, check your connection so it's tight. and there will be a master volume on your amp. feel around the back panel.. they tend to blend in
Mar 12, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
No output on the master but there are output on group and aus out
broken faders...bad muting fet on master buss, dirty insert jack on stereo buss...could be a lot of things, last drive stage to output, got hot neutral feedback on snake and blew the final stages...
Nov 13, 2013 | Peavey 16FX 16 Channel Mixer
Backlight on boss dr 880 failed
IM LOOKING FOR A LCD BACKLIGTH REPLACEMENT PART
Feb 07, 2013 | Roland Boss DR 880 Dr Rhythm Drum Machine
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Roland Boss DR 880 Dr Rhythm Drum Machine Logo
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
