Canon LS121TS How do I set my decimal place to only be 2??
SOURCE: decimal places
How many decimal places are in the answer of this problem? 3.7844236 times 456.93874513
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Default decimal settings
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
  • 7993 Answers
SOURCE: Decimal position
Here is a screen capture to help you.
Posted on Jan 30, 2010
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
SOURCE: show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Posted on Aug 21, 2010
What settings do i put on my canon p29-d iv for it to read with 2 decimal places...thanks
Hi Heidi,
Locate the slide switch with the following under it:
"+ 3 2 1 0 F"
Slide the tab so that the number of places to the right of the decimal point you want shown / printed is above the number - in your case it would be "2". You may also use the "+" setting, which is "add mode" for adding and subtracting 2 digit decimals - and is convenient for currency calculations. These two settings and "F" (floating) are detailed on Page 1 and 2 of the manual - that I have linked below for you:
http://www.canon-ebm.com.hk/download/manual/P29-D%20IV_P39-D%20IV/P29-P39-DIV%20English_P.pdf
Apr 27, 2015 | Canon Office Equipment & Supplies
How do i configure this calcualtor to round to multiple decimals and not the 2 decimal places it defaults to?
Use the middle slide switch of the three between the display and the keyboard.
The far left position sets it to two decimals, the far right position displays all effective digits up to twelve, the inner positions allow you to specify the number of decimal digits.
If you need a manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/calculator/HS-1200TS.pdf
Jul 26, 2011 | Canon HS-1200TS Calculator
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
How can I change the setting to print total the decimals. It is rounded off to the nearest one hundred.
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Feb 26, 2011 | Canon P1-DHV Calculator
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
Jun 24, 2010 | Canon P170-DH Calculator
Jun 01, 2009 | Texas Instruments BA-II Plus Calculator
Decimal places
Jun 04, 2008 | Canon LS-100TS Calculator
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
May 05, 2008 | Office Equipment & Supplies
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
jasbo
jasbo
