Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Wps button i have a motorola 8002a. i'm suppose to press te wps bottong. where is it? thanks
I was trying to set up my sony bdp bx320 dvd on my at&t network with a mvg510. The menue said I should pressthe wps button to continue.
You set up WPS by providing a key that you can use between the router and a connecting device. It adds all the details of your security without having to enter it manually. On the Motorola router, it looks like you just set it up in the router and turn it on. On the connecting device you enter the WPS key and then connect.
Here is a link to the router manual. I think if you look around in the router setup menus you'll find a place to configure WPS. Page 39 of the manual. http://www.ron-berman.com/wp-content/uploads/2011/11/nvg510manual.pdf
Feb 24, 2015 | AT&T Computers & Internet
Is there a WPS button on my Motorola SB6121 Modem?
I don't see it in the picture searching, but if this function will be able, you will see special button for it somewhere on your modem.
Feb 19, 2015 | Motorola Computers & Internet
Where is the wps button on my netgear08 router
If I am not mistaken, if you are facing the router the WPS button should be located on the right side, it is easy to miss because it is a recessed button. Look closely!
Thanks,
-Seth
May 17, 2014 | Arris SURFboard SBG900 Wireless Router...
I just purchased PIXMA MX452, I've followed the set-up instructions with no difficulty but I'm at a point where I chose WPS and it gives me an error response. I then chose the other option and it is...
Your router should support WPS. It must have a button that has two curved arrows one directed upward (the right one) , the other downward (the left one)
You are supposed to check the option and press the button on the router.
If you do not use WPS, your network should have a key (password, passphrase) that you enter when you connect the first time. Check the configuration of your network.
Oct 31, 2013 | Canon PIXMA MX452 Wireless Office All In...
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Apr 08, 2017 | Motorola Computers & Internet
Hp printer says to press the WPS button on the router. What's that?
  • Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections.
  • WPS lets you use push buttons or PINS instead of entering a network name (SSID) and wireless security by hand.
  • Push button: The WPS button is either on the product or a clickable button on a wizard or utility screen.
  • Personal Identification Number (PIN): The PIN is either on a product label or can be viewed on a wizard or utility screen. The PIN is entered for either the router or access point, or for the wireless device that wants to join the network.
Feb 01, 2012 | Linksys Computers & Internet
Were do i find the WPS button? I am trying to set up a wirelless camera and It tells me tp press the WPS button on the Router, Thank you for your help
in IE , type 192.168.1.1 , put user name and password.
then click on security tab from top. You will find the wps settings there. and at the back of some new routers, there is WPS button available.
Sep 16, 2011 | Linksys WRT54G2 Wireless Router
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Feb 10, 2011 | Arris SURFboard SBG900 Wireless Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
