Teco airconditioner remote control no working on my old split system Modle: Evaporator LS 2402 YPS
bobotfel
  • 236 Answers
SOURCE: MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
Posted on Jan 24, 2008
SOURCE: dont know what symbol on remote is for heating for
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
Posted on Jun 07, 2009
  • 340 Answers
SOURCE: The remote control won't work even though I have
bad remote control may something got spilled on it they do not like to get wet. Tom try google manufacture to get new is their power to the unit tripped breaker.Tom
Posted on Jun 21, 2009
skrbin
  • 121 Answers
SOURCE: cant get heating to work
adjust temp e.g. 39 deg Celsius or high and turn on heat,but first you must turn off air conditioner then select heat rating and turn on a.c.
Posted on Jul 05, 2009
  • 70 Answers
SOURCE: installation manual required for teco split
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Posted on Oct 06, 2009
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
I have a koppel split type airconditioner.my remote was deffective can i use a universal remote control chunghop.what is the code?
There is probably no code built into the Chunghop. If the Chunghop has a "Learn" function then you can teach it the commands using an original remote (hopefully you can borrow one).
Jun 08, 2016 | Universal Remote Control Televison & Video
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
My airconditioner will not turn on using remote control
Check there will be error code: If not check power to indoor is perfect. Error code details as follows
Code E3
Error detail Remote control transmission error(transmitting error)
Inspected unit Remote control.
Code E4
Error detail Remote control transmission error (signalreceiving error)
Inspected unit Indoor.
Dec 10, 2010 | Mitsubishi MSZ-A15NA Split System Air...
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
Auto delay on splits
All Split ac units have a safety system in them for a smooth switch over.
The delay time is different in all units especialy if they are "Inverters" or "soft start"
To be extra safe , just select prefered Temp and then Put it all on Auto.
Also some models have an anti tamper lock on the remote settings.
Feb 02, 2010 | Heating & Cooling
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Jan 24, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
